The Big Boulonnais
There is a small J shaped bracket that the tube sits in on the back of the cylinder head. Pull up on the EGR tube and it will pop out of the J bracket. The bracket can stay, no need to remove it.
Hi Seth,
I have now managed to remove that EGR Tube. It was no small job. I couldn't reach the higher bolt that fits that Tube to the EGR valve from above or under the Jeep as it is too close to the engine block. So I decided to drill through the Tube just before the flange. I started with 5mm hole then got bigger and bigger until I could put a Hacksaw blade through the hole and I managed to cut what was left of it that way.
Once that done I realized that Tube was broken at the exhaust Manifold end so the part that fits that tube in the V-clamp was still with the clamp at the Manifold. That must be the reason why I lost my Turbo boost last week.
I then removed the complete EGR valve but bizarre enough it is not exactly like the one you show in your install pictures.
I will put pictures of all the parts I removed on your site.
Also there are only 2 big cooling hoses that go to the EGR Valve. One from the cylinder head to the EGR Valve and the other from the EGR valve to the Top of the engine. There was no small cooling hoses connected to the EGR Valve.
I plugged the hole in the cylinder head with the bolt and copper washer and blue loctite once that hose and fitting were removed.
Anyway all this junk is out now Thank God for that !
Also on my Jeep there is no Y junction as such between cooling hoses. Mine are solid steel tube and the T junction is not removable as it is part of a long steel tube. I will have to cut it at each end and connect a bit of cooling hose today.
I will let you know when the engine is running.
