Cylinder 6 Misfire
MarkJ
What exact code is it throwing? People are giving all kinds of suggestions and the code should eliminate all but one. Instead of changing the cyl 6 coil I would have swapped it for another. That way in off chance you are identifying the cylinders wrong you would know exactly what happened by where the error code went or not.
Mark
LiquidSteel
Papillion NE
Similar issue with my 03 Liberty weeks after taking delivery on it. First I changed the plugs then the coil pack. I wiggled the wire loom that holds all the wiring (going up the drivers side-sorry I know yours is passenger side) and low and behold I found a wire that had all most all of the insulation rubbed off. I cut and replaced that broken wire and then wrapped the remaining wires with some heat shielding material left over from another project(the cheap plastic wire loom holding stuff).
Best of luck to you!
