First thing to do would be swap the #4 coil with a known bad one. It won't make the P0304 go away, but another code should pop up if the coil is the problem.
Hmm, forgive my ignorance, but I'm not sure what this'll tell me? If I've already swapped out coils 1 and 4 and the misfire remains at 4, wouldn't that still tell me that the coil isn't the problem, that it most likely has something to do with cyl. #4?
Could also pull the coil, and see if it affects how the Jeep runs.
Okie doke, no coil at all on #4. So... What will a change in the Jeep running tell us (me)?
This is all very free and very low effort, rather than pulling the head to take a gander at what's all up in dere
I
do appreciate things that are free and low effort. That's my kinda style.
Do you have any idea at all what the popping sound could be? My assumption is, now, that it's probably something in the valve train - is that assumption mistaken? Could it be something else all together? (Well, I suppose it could, but is it
likely?)
I've counted pops while in idle, and presently they're at every 2 to 8 seconds. No less than 2, no more than 8.
Would a Ouija board be helpful? Maybe the Jeep wants some sort of rooster sacrifice?
