dash idiot light ???'s
88dually
'03 Liberty 3.7l 4x4 auto. When battery light on dash goes on. Does that mean theres a problem with the alternater ?
88dually
Where does the neg batt cable goto ? Its wrapped in a loom an cant see where it goes. I wanna run a new neg cable. But where does it go ?
It's been a while since I checked mine but I think it connects to the block under the exhaust manifold on the drivers side. I've got a different project in the works right now so I can check mine in a bit but right now that's what I recall.
Actually it goes the other way. It is connected to the body near the battery. Rather flat spot above wheel well toward the driver with respect to the battery. I was following the wrong branch. It looks to be attached by a nut on a stud with another connector on top. So the (-) cable is rather short.
88dually
Whats really screwed up, its an intermitent problem. Some days light comes onn an goes off by itself. Sometimes it stays on til jeep is parked for the night. It usually takes z while driving before light comes on. WTH ???
That's what my Ranger did when the Alternator was going. When my KJ alternator went it just lit up and died very quickly. My 02 has a battery temp sensor on the tray Does your 03? If that goes flaky it'll throw the battery light too. I had to nurse mine home when the battery went years ago and the temporary battery didn't seat right in the tray so the light would stay on.
88dually
On my third batt an never saw anything on the tray. So I dont think theres a temp sensor. Most likely its the alt ?
I'd say you are correct. But just a guess. Alternators aren't to bad to replace based on cost and difficulty so if yours is original it won't hurt.
The temp sensor is a little plunger like thing in the center of the tray if my memory is correct.
The PCM -Power train control module may store a DTC code on the charging system.
I would want to have a scan done and see what hint may come from code if light is on.
Battery and connections are always first place to start. How old is the battery?
If you have removable electrolyte caps, get a hydrometer reading on each cell.
You could overnight put the battery on a charger and then see if light comes back on after driving as well...hint...
Load test it ...easy enough also to have a battery shop check it out for you with a digital tester and charging system analysis.
It is a good idea to replace the battery temp sensor in the tray when u replace the battery as well. Not an expensive part at all.
88dually
Its a used optima red top from a explorer my wife totaled 2 months ago. Put a meter on it, an all the numbers are fine, 13.1 not running. 14.02 running, 11.7 cranking.
88dually
Wife drove a 20 minute on way trip, light came on for about 3 minutes at the end. 20 minute ride home, no light.
Do you have a scanner to get codes? If not try key trick without starting from off to the On (no start) position. ..ON-OFF-ON-OFF-ON an leave it on ON..see what displays in the odometer...
Other wise I would have the ALT tested. When they get hot...stuff can go wrong.
yellocoyote
NW Chicagoland
Warning you that the entire battery harness is huge - lots of sections connecting to lots of different areas.
Looks similar to this:
Billwill
White River, South Africa
You need to pull codes out....as stated a faulty battery temp sensor also sets the battery light on. I had this problem....cannot remember what the codes were but they pointed straight to the battery temp sensor...not the alternator!
Make sure all the grounding cables are clean and tight such as the grounding cable grounding the engine to the chassis....you can get the codes out by rapidly turning the ignition ON/OFF 4 times without starting the engine...after the 4th time leave the ignition ON and the codes should display from the oldest to the newest.
If it is intermitant then check the cables on the alternator are on firmly...there is one thick cable going to the battery and a small plug with two wires....this is the regulation coming from the PCM as the alternator does not have its own regulator.
The thick wire going from the alternator to the battery actually has a built in "fusable link" but I am pretty sure that this link will either work or will be blown altogether...doubt it will be an intermittent problem.
You could try disconnect the battery and re-plug the connectors on the PCM in case there is a dirty connection and that is where the regulation comes from.
88dually
So much for the days of simple alt or batt cable problems. Lol
I have a scan tool for codes. Later on today I'll pull codes. What if there arent any ??
