DIY Jeep Mods You Have Done for $100 or Less....
monkyfart13
JPOTM WINNER
CHARLOTTE, NC
My DIY List
This is my list of under $100 mods that I have done myself. Im relentless in my search for good deals on ebay or craigslist.. enjoy :)
1) Bought and Installed a Kidde Fire Extinguisher
2) Removed my rear tire carrier and made a Hi-Lift Mount instead
3) Bought and installed a set of Mopar Tail Light Guards
4) Removed my Rear Sway Bar - Freebie :)
5) Swapped out the factory door hinge pins for a removable nut and bolt setup.. write up available on my cardomain page http://www.cardomain.com/ride/3389540/1
6) Bought and installed a set of Autopal 130w Offroad Lights... write up also available on my cardomain page
7) Installed my Cobra CB Radio in my glove box
8) Bought and Installed my Ballistic Fabrication Optima Battery Box
9) Cut my radio antenna down to 14"
10) Bought and Installed a Pair of Gryphon 7" LCD Headrest Monitors
11) Bought and Installed a pair of Alpine Type-R SPR-17c speakers in the rear
12) Bought and Installed a pair of Alpine Type-R SPR-17s speakers up front
boebr1
Helena Montana
That's a great idea boebr1 I'm always struggling to back up my utility trailer but can that lens easily come off of the window later without damaging the defroster?
One last thing, boebr1 that's not a trailer that's a wheelbarrow with tailights :D
Sorry I didn't answer earlier, yes, fully removable, no adhesive, it is a static cling. use the soapy water so you don't have air bubbles messing up your view. by using the soapy water, it will slide around really easy for a day or two til it dries
m_volyrakis
Greece
What happens when it dries? Can you easily remove it? does it leave any residue? can it be reused?
boebr1
Helena Montana
No residue. You can reuse it, just wash it with warm soapy water. Imagine just sticking a thick piece of plastic wrap to your glass... if you put a little drop of dish soap in a spray bottle of water, spray that on your glass. Put the lens where you want it, hold it in place while you use your drivers license to squeegee the air bubbles out from under it. Wipe up excess with paper towels. It'll dry in a couple days then you can use glass cleaner and clean everything up without fear of sliding it around. When you want to take it off, just hook it with your fingernail and Peel it off. Wash the glass with glass cleaner wash the lens with soapy water. It basically sticks on like a suction cup.
Bulli
South Africa
Monkeyfart13, good looking kj. Where did you get the stereo surround to fit a normal single din stereo?
Mind if i ask you for the part number of the mopar tail light guards?
I did a lift for R650. if you convert it direct it comes out to more or less $90.
Sold my 245/70/16 bfg a/t's and bought 4 new 15'' wheels and took over a set of 31/10.5/15 bfg a/t's from a friend and paid in $100, R700.
candpliberty
Las Vegas, Nevada
I built a custom GPS mount from a goose neck lamp that broke, part of a vent mount that kept falling off in a spirited turn, and some metal.
I found the goose neck wasn't strong enough to support the nuvi 650 so I but a solid 10 guage wire up inside. It still wasn't enough so I used a rubberized wire clamp attached to the dash.
The power source is hard wired into the on al the time dash power outlet with an toggle switch in the dash to shut it off. This way I can charge phones, etc without the key being on.
ndz
Bby BC
replaced stock shifter knob with a red snooker ball... then bedlinered it!
ndz
Bby BC
And painted the bezel around the deck red. I could not stand the fugly grey that didnt seem to match any of the other fugly grey interior.
Aaron2345
Tinton Falls, NJ
Yesterday. Sun the 23rd... installed OPTIMA red top I already had. Kinda freebie lol. Bought and installed cobra 25ltd cb basically brand new $30 ! Rear tow hook $30 and a real tree steeringwheel cover.$12 all that for less that 100 (gimme a break on the battery lol)
92fox
Fort Leonard Wood, MO
Subscribed...good ideas I've seen and will be doing to my new-to-me 2007 soon. Mainly the rear cargo area cover.
Adrian006
Ontario
Rear cargo shelf
Desk top(1" fiberboard) found online - free
Dowel + hardware - 5$
Bedliner - 9$
Fire extinguisher found online - 5$
White "accent" spray paint - free
Adrian006
Ontario
Made it look stealth.
used some old window tint I had laying around,
and water with a pinch of dish soap
so pretty much a free mod(for me)
Jbergun
Chicago
Flowmaster was $100
http://youtu.be/Rqqr5WAC-CQ
Spray paint the rims cost $20
Paint the entire under carriage cost $10 for a quart of paint and a brush
Big three electrical up grade used some left over 4ga practically free
Free decal stickers anytime you buy something
Like the flowmaster came with a bunch of stickers tire rack sent me stickers too so freebies
Plasti dip is cheap can flat black anything i hit the gas tank flapper thing looks cool
