hyedipin said:
I told them my brakes were different following the last brake job. Now, today I drove the loaner GC, all it takes is a tiny tap and it stops. With my KJ I have to put my foot and press down a lot more to get it slowing down (after my recent brake job). I will be going back tonight to pick it up, any ideas if that is a problem? It feels like slower I go, harder it is to stop. I have to push all the way..
Well, if the mechanic did a half-arsed job on the brakes and forgot to bleed them that may cause some of the problems you described. Another possibility that comes to mind is the brake booster, which you can at least do some visual checks on yourself. Open the hood and check the vacuum lines that run to the check valve - click on image below for larger view:
You probably know the white plastic container with the yellow cap is the brake fluid resevoir, and the large black housing directly behind/below it is the brake booster. The orange colored hose is the vacuum line that runs to the intake manifold on the engine, and the green one leads off to ??? ( I didn't take time to trace it out). They both connect to the vacuum check valve on the brake booster (blue circle). If either one of those is loose, disconnected, or has a leak in it that may cause the booster to not function properly, which would translate to your needing to apply more force to the pedal. Here is a shot of the vacuum hose attaching to the intake manifold:
Check this also to see if it is loose. There is one other test you can try - this is straight from my FSM:
DIAGNOSIS AND TESTING - MASTER
CYLINDER/POWER BOOSTER
(1) Start engine and check booster vacuum hose
connections. A hissing noise indicates vacuum leak.
Correct any vacuum leak before proceeding, also
ensure booster mounting nuts are torqued correctly.
(2) Stop engine and shift transmission into Neutral.
(3) Pump brake pedal until all vacuum reserve in
booster is depleted.
(4) Press and hold brake pedal under light foot
pressure. The pedal should hold firm, if the pedal
falls away master cylinder is faulty (internal leakage).
(5) Start engine and note pedal action. It should
fall away slightly under light foot pressure then hold
firm. If no pedal action is discernible, power booster,
vacuum supply, or vacuum check valve is faulty. Proceed
to the POWER BOOSTER VACUUM TEST.
(6) If the POWER BOOSTER VACUUM TEST
passes, rebuild booster vacuum reserve as follows:
Release brake pedal. Increase engine speed to 1500
rpm, close the throttle and immediately turn off ignition
to stop engine.
(7) Wait a minimum of 90 seconds and try brake
action again. Booster should provide two or more vacuum
assisted pedal applications. If vacuum assist is
not provided, booster is faulty.
I wouldn't worry about the POWER BOOSTER VACUUM TEST because it requires a vacuum gauge, but you should be able to perform the other checks to see how they work.
Hopefully you can get it figured out, if not then the dealer or a good independant mechanic should be able to. Good luck!
