DWM Seeks AJP For Wild Weekend, Maybe More
Did I Miss Anything?
  • Nope, You're Good. Go Ahead And Order It Already
    Votes: 7 70.0%
  • Yes, Dummy, You Did (Tell me what it is by posting in the thread)
    Votes: 3 30.0%
  • Total voters
Fired
WOW too much to read ..........many ah ,....interesting answers
NOW if I was you ( and I'm glad Im NOT! ) :happy175:
Dick! :fca5278d:
But I would run 927/948 combo...
The one I have listed above is OME part #2947. I'll change it for the 2948 then. Not really sure what the difference is.
On height, I would do the 927s plus a 1/4 inch top plate, which gives you 3 inches then only 1/8 or at most 1/4 inch clevis in front. Any more and you get real close to that spring / UCA contact point.
Is that the one called "JBA Strut Spacer Plate Set"?
As for the clevis, I don't see a 1/8 (.125) but there is a 1/4 (.250)
Rear two extra iso per side..
Two upper, two lower, or one of each?
Oh, and about that "Dick!" business - :sorrysign:
:happy175:
Dick! :fca5278d:
947s are about the same as stock but just with a little lift.
Is that the one called "JBA Strut Spacer Plate Set"? yes
use one conduit nut per side or just measure 1/8 inch up. No need to buy them .
Only use uppers you can add 2 plus the original for one inch of lift
I am at times, work very hard at it especially for some people , just to irradiate them some ya know.
:happy175:
:happy175:
Fired
Your efforts have not gone unnoticed. :Moon:
(Nor are they unappreciated.) ;)
Are the JBA bumpstops the same as the ones I linked above from Quadratec? Here are the JBA's:
TeraFlex Bump Stop
http://jeepinbyal.com/teraflex-bump-stop.html
I'd rather order them from JBA if they are.
Do I need the Y-Link Connector? I'm assuming I do, but don't want to buy it if I don't need it.
jeeplib05
Ohio
And shocks - anything there I can or should do better?
We're nearing the finish line. :D
I have the exact lift you want, OME/Bilstein and ordered from nearly the same places you did
The only difference is I didn't get the UCAs, y-link ext., etc and my rear springs are from Quadratec
I noticed you don't have the bushing kit listed in your parts
Make sure if you're getting the Bilstein rear shocks that you get that kit from JBA or it'll be a pain for you later since they're made for a YJ
You can refer to my parts list for the places I got my stuff and for the best price (Post #14):
http://ww.jeepkj.com/forum/f203/ome-bilstein-60258/index2.html
You will be very satisfied with your choice of parts
I have 3 conduit nuts on each side and one extra upper iso in the rear
I sit at 3 1/4" lift on all 4 corners
Fired
I have the exact lift you want, OME/Bilstein...
Is the Y-Link a "nice-to-have" or a "need-to-have"? I'm guessing the latter.
Any Ironman shock fans out there?
And...why does my spell-check not like the word "Ironman". Hasn't it ever been to the movies?... :emotions34:
KJ604
Vancouver BC
I dont know 100% but I dont think the y-link extension is necessary. I did not get this part for my lift which will be the same height as yours.
definitely get the JBA lifted a-arms though. they are worth the money.
jeeplib05
Ohio
I mean, if you are willing to buy it then I'm sure it goes both ways
It puts the rear at a better angle since after you lift it things are at an increased angle
So, is it nice to have? Yes
Is it needed? No
And to answer your other question, nothing Ironman is available for KJs anymore
I wanted the Ironman lift because it was cheaper but of course they stopped selling them right when I wanted my lift
I'm happy with my OME/Bilstein though
Fired
Dumb question of the day (hey, I made it until 11pm), but how much of a lift is determined by the shocks and how much by the springs?
See, I told you it was dumb.
ME
:signs75:
jeeplib05
Ohio
ME
:signs75:
The shocks don't add lift its the springs
OME 927/948 springs give you 2.5" of lift by themselves
Then you can add clevis rings and iso's to lift higher
The front shocks are all the same length but the rears have to be longer because if not they'll get damaged from over-extension
Jbergun
Chicago
The shocks absorb and give a smoother ride springs lift.
As for your clevis answer the spacer is just to measure. So you could in theory use a 1/8" drill bit or a micrometer then tighten down your clevis. There was a thread on how to do a clevis lift without disassembling the front. Just jack it up take the wheels off loosen clevis create space between clevis and bottom of the strut assembly and tighten.
Can't get the Ironman shocks so don't even think about them
At 2.5 inches -nice to have
2.75 inches up a must
Shocks control bounce
just for fun someday remove the rear shocks and take a slow trip around the neighborhood ! LOL
Fired
Any alternatives to the shocks I selected? I would feel better ordering if I knew there wasn't something out there I will wish I had bought after it is too late.
jeeplib05
Ohio
There are different ways to do a clevis lift
Either put spacers in or measure the distance
You put conduit nuts onto the bottom of the shock where the clevis attaches to and then slide your clevis fork up and tighten down
Or you measure 1/8" up to three times for each side to achieve the amount of lift you want- either with a tape measure or object you know is 1/8" thick
The conduit nuts make it easier for people that just want something there or don't want/know how to measure the space
jeeplib05
Ohio
Not good ones
The 132Ls are said to be done for so Bilstein is your only good option
Jbergun
Chicago
Yea if i remember correctly the guy in the tutorial used a 3/8" chisel but he didnt have a top plate.
Whatever you use just make sure to give the drivers side front a bit extra , it'll be level then
Gyro
Nova Scotia
I would use the conduit nuts,because the 07 has a smaller clevis pinch bolt that only torques to 45 ft lbs,not enough to hold the spacing by its self.
Unlike the 02-05.5 bolt which takes 100 ft lbs.
I tried without the nuts on my 07 they slid back to bottom on the first road test.
I have since installed a set of 04 clevis's with the bigger bolt but still use the nuts.
Gyro
