EL Glow Gauge Installation
myakubis
Ok, here's the deal. I know of many people who would like to do a glow gauge job on their Libs, but like me cannot find much help. I bought a Haynes manual and it is incredibly helpful and has a wiring diagram for the headlights and everything. The install (vague) recomends a consistent 12v source, but I only want the gauges to go on when the headlights are on (seeing that it only makes sense to need the gauges lit when it is dark enough). So any recomendations would be much accepted. Does anyone know the best way to access headlight power (through the fuse box or the actual switch bar?). Following a successful installation, I will post directions and pictures for anyone else interested on upgrading the look of the interior.
Here's the plan:
1. Remove Bezel
2. Remove Cluster
3. Install new Gauge Face
4. Wire Face and secure inverter
5. test gauges
6. reinstall the rest...
myakubis
I have completed the install, so if anyone would like to see it all done let me know. I haven't posted it mostly because I am a busy college student and maybe a little lazy. So let me know if you want to see it and I will post it as soon as I get the chance.
Seanpr123
I really want to see also...
SO GET OFF YOUR BUTT!
Signed,
another lazy college kid
Signed,
X2!! Im also a college kid, although I do study alot so I dont believe Im lazy... \:D/
Bennett
Active Member
Green Bay
I installed a couple of these for some of my friends.. pretty easy, but you have to be VERY careful not to touch the needles too much when installing the sheets as they are very easy to mess up. I mean you can move them, but just be careful.
I just always tapped into an illumination wire that lights the cluster itself. Does your manual say which wire it is? else I can look it up. From memory I remember the thing used a couple milliamps so I never used a relay, but a relay is never a bad idea for the most part.
Bennett
Gris
Scranton, PA
I can't really describ eit well, but the illumination wire is green with a yellow stripe. It's on the top row towards the passenger side if the plug was plugged in.
