mattjeep
I've been wanting the same thing to. I would love my foglights to stay on with the high beams. There has to be a way to override it safely.
CRD4Liberty said:When you do the install put a relay in the system and run pwer through a fuse to the battery. That way your only using a slight bit more power to activate the relay and pulling the power from a different source with the correct wiring size for the additional current draw. Most aftermarket lights have install kits that give you all the stuff necessary.
jeepjeepster said:You can post it in the how-to yourself. I would really like to know how you did this. O![]()
