The subject on oil pressure was brought up by me, because of the FL-1A filter I was using. Could not CRAPPY filters be a problem? IT was on subject... It was fine when I bought the Jeep, then I used a FRAM 3600 with the 1st oil change. IT was ok, even after the trip to Missouri (but where the ESP stuff started). The light didn't come on till I did a 2nd change, using the FL-1A, so, I figured an incompatibility of outer hole placement, or restrictive, and thought it was leaking. So, I changed back to the 3600 yesterday, it got WORSE. The oil light was on the entire ride to the office today. I carefully monitored the temp gauge, it did NOT move a hair, so it is not dangerous yet. I even pulled over to check the oil level, and the leak area, all was ok. It is an oil leak though, AND I thought it was coming from a CRAPPY filter seal, still on subject. On the way home, it only came on at idle again, so it's got to be the sending unit...
SO, I will just have to take it back to the Dealer for Warranty under Powertrain...
TonyCDR; About the hobby thing? I am not the one that starts this crap, it's them. I made a comment on My prior vehicles suspension, then he tells me what suspension it HAS, matter of factly? No dude, he's completely wrong, and he did not even have to comment, He CHOSE to, to make another issue, without a lick of research. I commented, he chose to smash it, and he's wrong on top of it; 100% in fact; and I had to prove it, and did so QUITE nicely, and correctly. Makes you question the reliability of prior, and future information from people, when they can be wrong so many times. I won't take a word he, oe the OTHER one, says into consideration, EVER, not after this latest lie, to try and start another fight. If you notice, it's only TWO people that are doing the antagonizing, and I refuse to sit back and allow it. If we were in a bar, it would be no different, arguing, and carrying on, but I could at least THEN, take him outside to SHOW him the suspension, if there was one in the lot.. Then the making me a grease stain threat from the other one, so, hey, I am not being VULGAR, or threatening people. My words are just put together the way they are... If people read them as hostile, then they need to see a shrink, because when you read, your own voice is the sound you here, not mine, so I don't have the problem.
