Front Inner fender bump trimming
Trailrabbit
Canada
What exactly is the purpose of the bump on the rear side of the front inner fenders?
I’m assuming a lot of you must have trimmed that off for clearance with bigger tires...
Is it safe to just cut it off or is there something behind it?
DO NOT/DO NOT just cut it off
just cut inner fender liner and pound it over , I can give you hints on how to do it so it looks factory
if you cut it you will weaken that area
That is where the unibody is welded together
You basically have 3 sections to a KJ/KK body
the right and left hand sides then the middle
what you see sticking out is part of that section where it is welded together
Its on here at least ten times more than likely but,
This is the way I have done 45-50 KJs
Tools needed
Heat gun
box cutter
3 lb hammer
Go about an inch above the pinch weld ( part that sticks out)
Heat the plastics up some since it cuts like butter with a little heat
Cut a " V " shape wider at the bottom and going to about an inch apart at the top
Heat the plastic and bend upward out of the way
with 3 lb hammer bend the pinch weld over and as flat as you can
If you think its hard, just think of an exwife/girlfriend etc LOL
After bending it over paint it to prevent rust
Now if you gently heat the plastic back up a little , you can bend it down and with some slow determination flatten the raised portion up and flatten it out against the exsisting inner fender liner, heating it just enough to blend/melt into the other
When done and if done right it will be hard to tell you did anything
I use a wide spoon handle type of pry bar to blend it in
Its so simple my son did it with just me telling him the first time without any help
I just sat back and explained the steps
His first "big" job after arriving in this country from Tanzania having never worked on any vehicle before
Trailrabbit
Canada
Aha.. Ok I’ve seen the pinch weld referenced a bunch I just didn't realize it was that same spot. Thanks for the detailed instructions! Ill give it a go tonight or tomorrow after work. Thanks!
jeeptorino68
Oregon
The hardest part is enough space to swing a hammer. Use a good sized hammer. 3lb
Trailrabbit
Canada
Got it guys thanks!
I will no longer be the prime suspect in parking lot hit and runs!
