Front Parts Questions
sleepyjim
Bullhead City, Az.
I have read so many lift posts, including the lift faq's, now I am confused...LOL well that is normal it seems, anyway, I ordered my struts and coils springs, ordered the terflex bumps, got a question on iso's for the front, do we order 4 or 2? also to get a bit more lift faq said spacers, I found 1/4" set on jba do we add 1 spacer per side or 2?
So happy to be ordering my parts! Gotta get the front done, tired of looking like a 70's hot wheels racer......
Jim
rjkj2005
US
Jim
The isolater pads are for the rear. Order 4 an extra 2 per side for the tops. For a total of 3 on top of the rear spring.
rjkj2005
US
Jim
Are you talking top plate or clevis spacer when talking about the .25 inch?
renegade 04
Albany New York
You can add extra lift using what we call a top plate that goes on top of the coil over assembly or by using spacers where the coil over assembly goes into the clevis fork at the bottom. You do have upper and lower idolaters in the front, but you don't add extra idolaters to the front for lift.
sleepyjim
Bullhead City, Az.
Ahh thanks for clearing it up.....
Is there a place other than jba to buy the top plate spacers and or clevis spacers?
Jim
Jim
Buy them from JBA, they fit properly
Just do top plate, that and 927 springs will give you 3 inches of lift
joncan
M
In other words, you can use the old isolators if you want to when setting up the front, or order new ones if you want to replace them with the springs and struts?
I ordered new mounts and isolators so I can take everything over to a friends shop and set up the struts before I start working on anything underneath.
