Glenn Buskirk
- Joined
- Jul 3, 2020
- Messages
- 14
- Reaction score
- 13
My daughter's '06 KJ is exhibiting the fuel burp problem on every fill-up. The pump is late to shut off and gas spills from the fuel filler. I have read the threads here on the matter, including the excellent guide for inserting a check valve in the filler hose. This procedure calls for sourcing the check valve by removing it from a GM filler hose part (15131046HOSE). I am not able to find this part in stock anywhere. I would like to ask if anyone has used this other type of fuel filler check valve. It is available to fit hoses with 1.5" and 2" inner diameters. Also, what is the inner diameter of the KJ's fuel filler tube? It is likely the same size as that GM part, but I haven't found that dimension either.
PS: I found an ad photo of the GM part that has, imprinted on the hose the dimension 1". I presume that's a 1 inch inner diameter. I'll be looking for a suitable check valve. Also, I don't know how they got away without a recall on this. It seems to be a real hazard in a rollover.
