jeepop
I pulled the propeller shaft to replace the starter. When I pulled the front of the shaft out there was some gear oil behind it. Actually started to drip once I removed a couple of the bolts. Not a lot, maybe an ounce. Is this normal or does this mean I have a pinion seal leak?
The good news is the fluid looked new from the bottle condition - 4 wheel drive is rarely used, and when we do its 4 high.
