johnnygrace
Hey friends I've got a Ginormous air con leak.
Backstory - ac clutch was not engaging, tested voltage at the sensor, it read 12v, jumped the pins at the fuse and sure enough the clutch engaged. I put the diy R134A can on the low pressure port and began filling. As soon as it went in, out it came from drivers side. It was loud enough leaking out that I could hear it with the engine running. Sounded like a compressor blowing out air. Anyhow I suspect I need to get the R134A with UV dye to find the exact leak.
My question is after I fix the leak, pending locating it, what do I do next? I don't have the tools to pull a vacuum. Should I just take it in for that part of the fix or is it cheaper to buy the tools? Is there anything else I should do/check, anything I might be missing?
TBH I was proud of myself measuring voltage and jumping fuse to engage clutch. Was satisfying finding the problem methodically and it actually working for once
