Glow Plug Code 1267
jwilinski
I’m getting this code. 1267 - glow plug(s) issue on my 2005 Liberty CRD diesel. It starts fine when temperature is above 5 degrees. But it runs normal with no problems. It’s been about a week since the code popped up. Although the weather has gone below zero twice during that time and I had to jump start it. I’m wondering what to do next. Or if I can just deal with the jump starting on the few and far between below zero days and then in the Spring and Summer it will be fine. Wishful thinking I know. Also, the engine light won’t clear. Is fixing this going to be big bucks? Need advice.
The glow plugs aren't particularly expensive, a fresh set should help.
Does anyone know what type of glow plug I would need exactly?
It depends what voltage your glow system is, I think there were 3 different setups, 5v, 7v and 11v.
Unless jeep can tell you what you have you will have to check with a meter or take one of your plugs out and hope it's marked up.
I think all the earlier non VNT Jeeps were 11V, the later ones 5&7v Jeep were doing an upgrade from one to the other to get rid of the ceramic tip plugs but I don't know which ones are the upgrade.
jwilinski
My mechanic replaced all four 7v glow plugs. But the problem of starting the vehicle is still a problem. When the car has been sitting there for an hour or more, it starts fine. But then when I drive it for 15, 20,30 minutes and turn it off. It won’t start again. But if I use the remote start it starts! Yes, the guy who owned it before I did put in a remote starter. So my question is what the heck could be the problem?
That's an odd one! The remote start must be interfering with something, do you have any information on how it's wired in?
Wonder if it has an immobiliser function with a time delay (can't think why though?)
Might be worth seeing if there is a manual for the system you could download.
The usual culprit for no hot start is a crank angle sensor on its last legs but I don't see how the remote start would work with that?
