Harbor Freight Tools
What about the new dual pawl 90 tooth SK ratchets? I've been thinking about getting one. I'm a fan of SK stuff for some reason.
Not as smooth or strong as the Snap On 80 tooth.
I have there 17" 3/8" drive 80 tooth and bent the bar 15 degrees and did not break the internals.That was my full weight(210lbs) jumping up and down on it with a 4' cheater pipe on the end.
The Snap On guy's face was priceless when I handed it to him for warranty,he still has it on his truck to show how strong it is.
turblediesel
memberable
Alaska
I bought a 14" chain saw at HF on sale for $40. Has done a good job so far. If I anticipated having lots of wood to cut on a regular basis I would have gotten a better one, but for what I'm doing I think this was a good deal.
$40.00!!!! I don't understand how they can produce something with an engine/motor in it at that price. And ship it across the ocean. And make a profit.
A chainsaw is one tool I wouldn't buy from HF. There's enough danger to chainsaws and tree work.
I like my 18" Husquevarna 350 a little better than my 18" Stihl 250. Gave up on Homelite long ago. Saved a 14" Craftsman/(Poulon) out of a friend's truck on its' way to the dump. No safety features on it at all. Cleaned the sawdust out of the cooling fins and cleaned it up. Works great up in a tree and handy to have on a snowmachine.
Want to buy a 9.4hp engine for your chainsaw? Will spin up to 20,000rpm's(about 8000rpm's more then any chainsaw engine can).
Fired
$40.00!!!! I don't understand how they can produce something with an engine/motor in it at that price. And ship it across the ocean. And make a profit...
Regular price was $50. But, yeah...
https://www.harborfreight.com/14-inch-electric-chain-saw-67255.html
I have a bunch of small trees (maybe 4-6" diameter trunks) that someone chopped down and stacked in the back of the yard. I got tired of sawing them with a bow saw. Once they are done I will probably not use it very often. I did cut some 12" diameter logs (very carefully and slowly) and it did surprisingly well.
justjeeps
canada
I relocated to Canada and they do not have Harbor Freight here.
Needless to say there has been several occasions where my first thought was " " Harbor Freight has it and it is only xx$. The last time I thought about H.F when I needed a vacuum pump for the ac. I ended up going the A/C compressor option to fabricate one out of a window unit.
If one lived close to the border they could make $ assuming there was a H.F near the U.S side.
Fired
Just to follow up on my $40 HF electric chain saw, the proof is here:
(Itchy Beagle added for scale.)
The previous owner had cut down several trees and left 6' logs piled here and there. I figure I would have had to pay someone $40 to come over and clean this stuff up, so anything I get out of the chainsaw from here on out is a bonus.
BillyG
Lynchburg, Virginia
I like the LED lights with the magnet on the back- they stick well to the frame when working under the Jeep. Plus, you can usually get one free with a purchase of anything else.
I have a couple of pry bars, lots of tarps, shop towels, measuring tapes and a set or two of the cheap free screwdrivers. I did get a couple of heavy-duty breaker bars that I keep in my Jeep and the wife's car for changing tires in an emergency. The sad part is that the sockets that are on them are probably worth more than the breaker bars.
I inherited a lot of tools from my grandfather- he used to work for Bethlehem Steel in New York back in the 50's to 80's- so they are all high quality items. I doubt that I would trust anything serious to HF tools.
M38 Bob
Arkansas
As a professional grease monkey I've always bought SnapOn and Matco. In the past few years I've figured out I probably ain't gonna do this for too many more years (plan to work hands on till I can not) but at 63 "lifetime" ain't as long as it used to be.:Insane:
The lower quality warranted stuff from O'Reilley holds up well. I've even tried some Kobalt from Lowes with surprisingly good results. I'll NEVER buy a hand wrench from HF!
A local town has a HF just recently and I had to check it out. From my one walk through it seemed the bargain stuff was junk, the non junk stuff wasn't a bargain.
Myke
USA
This is such a great way to describe 90% of their stuff.
Depends on what you buy, set of impacts have taken over 55 KJs apart , not including mine a lot of times , none broken etc
About 15 years old now at least
Of course I have Craftsman tools I bought in the early 70s as well that still work great
