BrianB
I'm having a problem with the temp of the heat coming out of my vents, don't know if it's a problem with the heat blend actuator and/or the the heat blend doors. Heat comes out luke warm at best no matter what the fan speed is on.
Radiator, thermostat, hoses, water pump, rad cap all replaced within the last 6 months. Jeep doesn't overheat and temp gauge runs 1/2. Coolent level is at cold level when Jeep engine is cool. Both hoses going to heater core are hot.
Running out of options. Also where are the exact locations of the heat blend actuator and easiest way to get to it w/o removing dash.
This is the wife's car. I drive a 96 XJ and runs like a top. The liberty is killing me with all the problems in the last couple of years.
Any help will be appreciated.
Brian
Brian
