J'sJeep
Reversion is not a term I am knowledgeable on. What exactly is it?
Cheap gas and/or reversion builds up a lot of sludge in the induction system. If you put any more money in it, do the fuel injector cleaning 1st. And if you buy the bottle stuff again, get Chevron's Techron.
Don't forget that 93 octane is harder to burn, not easier.
Adding injector cleaner or running high octane gas will do nothing for reducing carbon buildup in the intake,does wonders for the intake valves but that is it.Don't overuse the stuff,can and will damage your cats if overused.Once a year is all that is needed in addition to the cleaners in quality gas to begin with.Exhaust gases in the intake tract.
Well aamco had no answers and could not even replicate the stall. My trans is bad though. $2000 dollar job. Shit.
I already disconnected my AC. Just dud the other day because when the magnetic clutch engages and the AC unit pulley runs the compressor it clicks and a technician told me it was bad and if it seized while the magnetic clutch was engaged the idle pulley, that rotates independently from the AC compressor when the magnetic clutch is not engaged, would completely stop and would ruin the serpentine belt just like what happened to Up Liberty. Now it should not be a problem for me as long as its disconnected. No stalling issues do far or rpm dropping. I'll keep you posted. ****** rebuild coming soon, on a different note. $2000 down the drain.
