J'sJeep
Yes I do. Rattles though while engaged. If it seizes while engaged I have to replace it. I would rather have running jeep w/ no air then chance it.
As for the induction cleaning I've done seafoam in through the gas as well as through a vacuum hose just after the throttle body to get the pistons, cylinders and head. I have also heard that you're not supposed to clean the intake portion after the throttle body due to lubricants on the walls being a necessity and removing them can be ******* it.
I'm only posting as a discussion I'm not quite 100% sure but I know my sources are experienced.
I never heard of lubricant on the intake walls. Still so far your fuel injection is not 100% clean. Have you removed your air cleaner hose and looked inside the throttle body? There could be a ridge of gunk on the inside of your throttle body blade that is causing all of your problem.
When it is professionally done - Stuff does go in the tank, probaby stronger than what you can buy. They also force cleaner in to the injectors under pressure through the fuel rail and they remove the throttle body and clean it and inside the intake. Last time (and only time) I had this done on another car, I felt the difference as soon as I let out the clutch.
Now this would be a garage rip-off if your KJ was running fine but it is not.
Replacing sensors trying to match them up with a driveability problem is a crap shoot.
And to reiterate - do you use top tier gas? Have you bought a bottle of Techron yet?
