High mileage club
Bushmonster73
Junction City, Kansas
166,400 miles, started losing the rear passenger wheel bearing (funny sound when turning and you could wobble the wheel even though all the lugnuts were tight), made it the 25 miles home and got it changed. Had a lot of shavings stuck to magnetic strip in the rear pumpkin so cleaned it all out. The bearing compared to the new one did not seem too bad but the seal was rusted out and now 200 miles later everything is fine.
jeepontruckin
nova
395,000 on my 04 2wd.
Original engine. Changed the ****** at about 300k. had the steering rack replaced, water pump, 3 alternators. overall, no major issues. Interior is shot, but I've got 4 kids, so that's to be expected. That's next on the list to be swapped.
Am I the highest so far?! I hope so because I am very proud of me purple machine!
Mangate
Mexico City
Is that km or miles?
starrider06
Bismarck, ND
117,000 miles on 2003 Limited. Rear joint on front shaft, radiator, heater core, rear upper control arm. Airbag, ball joints, and fuel tank issues all done under recalls. 4 coils since original owner never replaced plugs. Cold weather pcv conversion as per TSB 25-001-08. I don't count wear and tear items since they are normal or induced by the driver....
Badgoat
Plant City Florida
05 150,507 miles. I am not the original owner. It has started jumping out of first gear unless I keep my hand on the shifter and the a/c blower motor will need to be changed soon but that's about it other than tires, wipers and a battery :)
dapper66
Denver
2002 Limited just rolled 129,000
2002 Limited just rolled 129,000, I've only had it a few weeks but enjoying it so far. The only thing I've had to do is tires this far. Still have my temp tags.
RRWA
Seattle,WA
2005 Jeep Liberty 188k miles
2005 Jeep Liberty Sport 3.7L 4WD 188k miles
recent gas mileage: 18 mpg
oil loss: about 1 quart per 500 miles
Recently replaced a few things which were broken:
-radiator (Spectra)
-radiator cap (Mopar). Old one had cracked rubber and held NO pressure.
-water pump (AC Delco)
-AC condenser (Spectra). Old one had a hole on on driver's side by top mounting bracket.
-AC accumulator
-tailgate latch
-PCV valve
-TPS - Throttle Position Sensor
-alternator
-transmission filter and replace half of fluid. Last service was 88k miles ago.
-lower ball joint replaced by Jeep under factory recall
-transfer case position sensor
Up next :
-trailer hitch from Jeep, under factory recall
-spark plugs. Original ones are still going strong, but the electrode is almost burnt away.
-my engine is sludged badly, based on removing the oil filler funnel and looking inside the block. I am trying GUNK flush, frequent oil change, Marvel Mystery Oil, etc. Piston rings may also be stuck, causing my oil usage(See above). No leaks on ground. No smoke from tailpipe.
rschilds27
Virginia
2007 Sport 126k
1 water pump
3 window regulators
A/C compressor failed two years ago, on the to do list.
PalauRoc
Washington
'02 Liberty Sport 3.7L(Basic) @ 149,900 miles. I need to replace front struts and springs.
Replaced: ignition switch, Left break hose
Rowlette
Florida
2005 Liberty Limited 3.7 @ 149866 miles
Replaced
Speakers
All Lifts Hood and Rear Window
Water Pump
Radiator
2 Window regulators
A/C Compressor and Dryer
Rear End
Now lookin to Replace
OEM ENGINE COMPUTER UNIT P56044576AI 3.7L AT
ElCheapo
Erie PA
'05 sitting at 115k right now. Let's see, so far I've changed the front wheel bearings, serpentine belt, trans and transfer case fluids, and power steering pressure hose. I need to change the rear wheel bearings and seals including the pinion seal, rear u-joints, and front struts/springs.
twowings
Tulsa, OK
'04 Sport a relative baby at 85,000 miles.....
Leak detection pump
Purge solenoid
Springs
Struts
Shocks
acvw74
Missouri
04 Limited
154800 miles
In the last year:
New water pump, rack and pinion, steering pump
mikeyd
Connecticut
I have a 2004 sport with a little over 164000 on it. I am not the original owner, but so far no problems except my wife's little fender bender.
04Liberty
MD
I never got to push the Jeep over 100,000 before the ex-wife took off with it, but if you email Chrysler with your vehcile and mileage, they will send you a pewter license plate frame; they have 100,000, 200,000 and 300,000 mile club frames that I know of. I don't know if they offer a KM version for our neighbors north. I have one on both the Ram and Charger.
Apparently they have a 1,000,000 one as well...
Johnny Z
new york
Hello everyone, I'm a new member and my '07 sport just reached 215,000. 1 water pump, 1 front drive shaft cv joint, 3 sets of brakes and 4 sets of tires. Not too bad !
So just email Chrysler for the frames ?
have a link or ????
