How to adjust Iron Rock Offroad control arms
KingKJ
The Rock Spotter
Utah
I am going to be installing IRO control arms with my new lift kit and am wondering how you adjust the control arms, and how do I tell where to correctly adjust them too? I haven't order the parts yet so I'm unsure if the instructions in the box will include this information or not.
klc
“It flies like a truck.”
PNW
Try searching the forums. I know this has been discussed by others who have installed them. I’d like to put some on mine eventually.
WWDiesel
Central Georgia
If you are installing both upper and lower adjustable IronRock Control arms, then you need to adjust them so your pinion angle is very close to the same as the output shaft angle coming out of the end of the transfer case. See drawing.
  • Like
Reactions: klc
