TwoBobsKJ
So for replacing the passenger side cv and intermediate shaft, is there a seal on that end of the diff that needs to be replaced? Or all the seals in the intermediate shaft and CV? Is the intermediate shaft held in with snap rings?
Unless there is a leak from the passenger axle seal I wouldn't bother replacing the seal. It can be a pain to swap out from what I've seen here on the forums.
The intermediate shaft is held in the diff by a snap ring just like the one on the CV end of the shaft. If your CV comes off the shaft when you go to take the CV axle off then you'll need to grab the intermediate shaft with a pair of vice grips and give it a good hard tug and it'll pop out. If the CV axle and intermediate shaft come out together (which is common, but as well as you take care of your KJ it's unlikely you have rust around there
