HOW TO: Change Spark-Plugs
oddball
Thought I'd add, if you've ever had a problem removing spark plug boots- There is a spark plug boot wrench to make the job much easier.
Anyway, next time you change plugs, use di-electric grease on the spark plug terminal. Not only will this protect the plug & boot from water, this will also make it much easier to pull the boots next time you change the plugs.
karter
Ohio
Hello all ,I'll add my 2 cents worth . Swivels and extensions tend to crack the spark plugs both installing and removing them . 2 -10 mm nuts to remove the radiator tank and you will have a straight shot to the back plug . Also ,if your socket doesn't have the rubber insert to capture the spark plug ,loosen the spark plug , leaving it installed a few threads and use a 6 in. piece of 3/8 fuel line hose to slip over the plug for removal. Do the same for install . Use a very small amount of anti-seize lube on the spark plugs threads ,less is better in this case .
jnaut
Seattle
Yeah, they're ceramic so any lateral pressure on the ceramic shaft is, well, potentially dangerous. My opinion you shouldn't be putting a lot of pressure on the plug in the first place (I understand TPI MONTE indicated he hadn't changed his in 7 years... so). Given the rather light torque required for the plugs, if one is careful, you shouldn't have any problem.
kb0nly
Planet Earth
No spark plug boots on the KJ!! :D
CRD Joe
Cle Elum, Washington
Yeah, you keep telling yourself that. :rolleyes:
Last tank. Combined city highway, around half and half was 30.8 MPG bubba!
Ive gotten 38.8 MPG on highway trips before. I can keep telling myself that all day long!
ThunderbirdJunkie
Bronze Supporter
Newport, KY
Hmm. ThunderbirdJunkie needn't make any modifications to his powertrain for reliability:D
Silly diesels :p
(Of course you know We keed)
Liberty06
Reno, NV
I did it! They were gapped waaay out of line as the end was burned down on the igniter.
I used platinums and wow what a diff...
RageOfFury
I have a question about the Autolite APP5224 plugs. The metal ring seal isn't already on the spark plug, its in the box. Each of the 6 plugs I bought are like that. Which way does this ring go on? Here is a pic of what I am talking about :
See there is a flat side and a rounded kinda side...:confused:
mag03kj
LOST
ya when i changed the sparks in mine all of those things where off the plugs
Jomac
Madison, Al
You must use a special gapper(plastic or compsite) to gap platnuim plugs our you will destroy them.
Always go by what the emission sticker under your hood says for plug gap.
how will this destroy the plugs using a standard (metal) gapper?
