ThunderbirdJunkie
Bronze Supporter
The battery is what powers everything anyway. Why bother upgrading the alternator?
I don't think that is the case. The KJ alternator only has two connections. One is the main output which goes directly to the battery and the other is a two-wire connector as in any standard 3-wire alternator that I believe goes to the ignition switch and indicator based on the wiring diagrams I have seen... and of course the case is grounded to the block.
Now after the battery everything is managed by the computer...
John
P.S. Nice ham shack by the way!
As long as the engine is running, all of the power for the accessories is delivered by the alternator. The battery is actually a load on the charging system. The only time that the battery would supply power with the engine running is when the current capacity of the alternator is exceeded or when engine is at a very low idle.
KB-ThunderbirdJunkie slightly misspoke.
The bulk of the power still travels through the battery, even if the battery is not directly powering it. Yes, the alternator DOES power everything, but it has to travel through the battery for it to act as a capacitor as you described. If it travels through the battery then the battery is powering it![]()
OPERATION
The charging system is turned on and off with the ignition switch. The system is on when the engine is running and the ASD relay is energized. When the ASD relay is on, voltage is supplied to the ASD relay sense circuit at the PCM. This voltage is connected through the PCM and supplied to one of the generator field terminals (Gen. Source +) at the back of the generator.
The amount of DC current produced by the generator is controlled by the EVR (field control) circuitry contained within the PCM. This circuitry is connected in series with the second rotor field terminal and ground.
As you can see.... The PCM controls the field of the alternator. So if the PCM is programmed for the smaller rating alternator you could put in a 300 amp alternator and it wouldn't matter, it would still charge at the stock rating. The problem is the KJ alternator doesn't contain the regulator, thats all handled by the PCM. Its not like the good old days where you can slap in a huge alternator to carry the loads. I don't know why they went with such a small alternator either. Even the minivan we used have was a 160 amp.
