HOW TO: Find a How-To not listed here & Forum Guidelines
MoladoGuy
DeTrOiT (Actually Warren)
Re: removing or disabling of the buzzer
dune_cowboy said:
Hi there MoladoGuy
No I have a speed alarm , buzzer/ chime the same as the seat belts ,but i can not find it, so I was hoping some one out could help me out as i need to pull the plug on the unit.
Regards
Dune
Okay. Looks like you have already been discussing this topic. Why post it again???
http://www.jeepkj.com/forums/viewtopic.php?p=20924&highlight=#20924
BCM needs to be reflashed. It's not just a cut the wires act...its programmed into the system.
dune_cowboy
Muscat Oman
Hi MoladoGuy
I need to disable the buzzer/chime .As I have a speed alarm (when I go over 72 mph ) on my KJ it works off the same buzzer/chime as the seat belt ,and i need to pull the plug on it .That is why I am posting it
Dune
Liber
Front door speaker Install
has anyone already written a "how to" on installing front speakers to a KJ with the infinity upgrade, meaning it has the two mini amps with the speakers in the front doors?
I would like to install my own if I could. But there seems to be a lot of wiring going on.
sudistes
how to remove rear bumper on liberty
All is said
if you have pictures, i am not english, that could be useful
thanks
N / A
can we get a transfer case oil change how to?
hyde
Hello, does anyone have any idea how to remove the steering wheel housing cover in the dash, there are two screws underneath, but when I fiddle with the plastic it feels like they are glued together. A project requires access to key cylinder, and I don't want to break it! (Steering wheel mounted stereo controls wiring re-route)
BluPhant
Connecticut
I took that apart when I was installing the foglights. It's kinda a pain in the side to get it apart, and I dont have any specific recollections to help you, but check the Foglght install PDF for a nice picture of the two screws.
Good luck-
-Blu
hyde
So there are no brakets or clips holding it there, from what I can see in the pic. Normally things screwed in jeep have some play, and you can tell, but that part feels like there was something else holding it. Good to know, thanks!
Mrgjeep
HOW TO: Replace Front Shocks
I bought a 2002 Liberty with 73,000 miles and found that it was porely maintained. The spark plugs that I removed were worn to the porclin. Anyway I having the deler change all of the fluids. In addition I'm going to change all of the shocks. I looked at the manual and it indicated that I have to separate the lower ball joint to replace the shock and spring assemble. Has anyone done this without separating the lower control arm.
Lizzys07Liberty
Albuquerque, NM
Liberty Guru's, help clueless newbie install basic stuff!
OK, so I'm planning on buying the front and rear tow hooks for my 07 Liberty. In addition, I'm also going to buy the much advised skid plates all around...all through that JParts.com place. With the free shipping it seems like a decent deal...though if anybody knows better, I'm all ears!
So my question is...When you order all this stuff, does it
A.) Come with the hardware needed to install it...bolts and stuff?
B.) Come with instructions on where to mount all of it?
(by this I mean super elementary stuff...like is it obvious where the
bolts would screw in with the skid plates and hooks once I got under
the Jeep?) Second part of the question, do I actually have to remove
anything to install any of the skids?
C.) With the tow hooks (front at least), I noticed that there are two plastic pieces of the bumper that appear they might pop out (as the pieces are outlined on the bumper), though I'm not sure if they really do, can anyone confirm this on a 2007 Liberty? I'm not sure if I want to use a Dremmel tool on a one-week-old vehicle quite yet!
I just don't want to spend near $300 and have to be stumped installing anything...and end up taking my purchases to the dealer and having them install them. ](*,)
Thanks in advance for the responses, and reading the long post! =D>
Corwyyn
Southeast of disorder...
All needed hardware *should* be included with the parts you are ordering. If it isn't, call JParts to confirm if it got left out. Mounting the skids should be relatively simple - there should be threaded holes already in the frame for the engine and gas tank skids, but for the transmission and t-case skids you'll have to install the super-nifty PITA DC nut-serts. These will go into hexagonal holes in the frame and then you'll mount the skids using them. All of the items should also come with those wonderful, cutting-edge German-type pictorial installation instructions; very minimal writing, but lost of pretty line drawings \:D/ As far as the front bumper goes, I think you'll need to cut the sections out, but it should be thin plastic at those points and easy to get thru.
I wrote a thread a while back on installation instructions for just about every option you can get, you might look thru these before ordering just to be sure you know what it's all going to take. If you have any more questions just post up - there's plenty of people who've already been there and done that!
Lizzys07Liberty
Albuquerque, NM
Good stuff with that page you made! Got that thing bookmarked now!
I'm sure I'll chime in with more questions as the parts arrive, but certainly appreciate the early advice and help \:D/
Thanks again!
02LibertyLimitedChick
Florida
Forgive me, I didn't see it posted here....does anyone have a basic how-to on how to install a Bull Bar? I ordered one and it's coming in the next two days and I'd feel better if I had a basic outline ahead of time. Thanks!
Lizzys07Liberty
Albuquerque, NM
Regarding the tow hook (front) install.
The instructions appear to be for the older style bumper, where the fog lights are integrated into the bumper itself.
http://site.justforjeeps.com/guide/82206124.pdf
Whereas, for my Liberty at least, the bumper is a little different, as the fog lights are built into the grill.
So, if you take a look at this dealer stock photo, it appears that the bumper doesn't need to be cut out...but to my understanding the perforated notches in the bumper (just above the tow hooks in the below picture) I thought it was basically the "guidelines" for where to cut the plastic to install them? :-k
Any ideas...or anybody with a newer Sport that has installed them?
Thanks everybody!
Florida
anybody?
Corwyyn
anybody?
Which one are you getting (brand/type)? Might be able to track something down with more info. I believe most of the bars made for the Liberty use the front tow hook mounting points, so it shouldn't be too difficult to do.
plchapy
canada
car lighter
hi i would like to add another car lighter in my liberty but i want to shut the current with my key how can i do that because the only power source on mine is always on and its not good when i plug my gps it doesnt shut off when i leave the truck
thanks
JFIVE
Rotors
Can someone please explain how to change my rotors on my 02 Jeep Liberty...thanks
Re: Rotors
Jack vehicle up,remove whell/tire,remove 2 12mm bolts holding calipher on and tie up out of the way,remove pads,remove 2 bolts holding the calipher mount to the knuckel(21 mm I think),and then remove rotor.
