HOW TO: Find a How-To not listed here & Forum Guidelines
seraph037
southeast Texas
Need Help!
I really need to know how to change/(install aftermarket)/fix horn. my horn works when i push the lock button on my keyfob, but does not i push on the steering wheel. this is preventing me from passing state inspection, and when i tried to have a mechanic check it out he said it was "the clockspring and will cost around 400$". I do not have the cash to spare to fix a button, so am looking for a DIY solution. I have searched online, but my google seems to be broken because i have had no luck. :mad3:I would greatly appreciate any help you guys can give me!
BTW: I am not sure if i posted this in the correct place as this is my first time posting here, but i do love this forum!
Hedsic
Des Moines, Iowa
I would like to see a how-to for installing an ARB Airl locker. I am not sure if this is something that must be professionaly done or what. If not, I would like to see how. idealy you would just get it done while regearing I know but it would be nice for knoweldge sake to see a how to for it.
Kapox
Venezuela
I'd like to learn how to replace the oil pressure sensor.
Hello everybody, I'm looking for a detailed guide to do this. I'm having a little leak of oil trough the oil pressure sensor, but not having any pressure loss, so I won't replace it, just put a new gasket on it. But I don't know whick socket do I have to use to unscrew the sensor. I've saw in a youtube video that is a 27mm socket but I used it and it doesn't fit, so I read it's the 1 1/16" deep socket that I have to use, but I want to be sure. Any help will be priceless. Thanks.
I don't recall seeing a gasket on my replacement mopar oil pressure sender.
You'll probably need a deep socket for it.
Kapox
Venezuela
I don't recall seeing a gasket on my replace mopar oil pressure sender.
Sorry I didn't meant gasket, I'll try to seal it wth some red silicone. If it doesn't work, I'll have to buy a new one I think, thanks.
my replacement had thread sealant on it already.
Not sure if you'd want to try RTV on it.
May be on the outside?
M38 Bob
Arkansas
Kapok, you're wasting your time. OP senders don't go thousands of miles then suddenly start leaking at the threads. It'll be leaking through an internal seal and needs replaced before you have catastrophic oil loss.
Sent from my iPad using Tapatalk
M38 Bob
Arkansas
I would like to learn how to change the front wheel bearings(both driver and passenger) Mine both need it and I would like to do it myself.
Don't have to. Be a Nobel winner, just basic tools and a willingness to bust an occasional knuckle.
Brake assembly must be removed, axle nut ( pretty big, make sure you have a socket and break over bar that'll fit before starting), then remove 3-4 bolts on back of spindle that hold bearing in place. A torque wrench is mandatory when retightening axle nut.
jp7794
I see new U-Joints in my future. I searched but couldn't find anything on pulling the drive shaft and replacing the U-Joints. Any help would be appreciated.
islandjeepster
virgin islands
Hey everyone!
We're trying to build a repository of helpful how-tos for everyone to use. If you've done something interesting and can detail the process, note it here. If there's something you want to do and would like a guide, reply to this thread and as a community, we'll try and provide it for you.
This forum is open to everyone newbie and veteran alike. While good natured ribbing is acceptable, chastising anyone for asking newbie questions is prohibited, so please feel free to ask for anything you want.
In order to keep the forum clean, If you would like to request a topic, please reply here. The only time to start a new thread in this forum should be when you're posting a new How To guide.
Disclaimer: Please note that the HOW-TOs here are based on our experiences with the Liberty, or based on service manual recommendations. Please bear this in mind when attempting to replicate any how-to listed here. Most of us here do this as a hobby, and are not certified mechanics.
Thanks!
-Blue Phantom
I have 06 liberty and mechanic said I need a new steering shaft. I would like to see a how to replace it with and explanation of each part; lower, middle and upper shaft because these parts are expensive and sold separately but parts guy wants to sell you all three as one unit and maybe I only need one of them ? lots of slop when I grab rubber boot just above where steering shaft attaches to rack and pinion shaft. Thanks
ScamSurvivor
Washington
My apologies for not seeing/understanding what this thread was earlier.
I have an 06 Jeep Liberty 3.7l 2WD Sport.
Looked for how to change the radiator and water pump but had no luck and ended up documenting my experiences in a How To thread in case it was useful to another first timer. I was going to add photos later but not sure if that's appropriate, happy to take direction :).
What I was searching for this time was how to replace brakes/rotors/calipers. I've seen enough on similar models (2002 and 2004 etc) but given there were differences in the radiator/water pump/coolant flush demos wondered if there was anything on the 2006 anywhere?
deepjeep
USA
Hi guys, I'm new to the forum and I am looking for a 'How to' on replacing the entire battery cable and terminal on a 2004 Jeep Liberty. The current terminal was so corroded that it's about to fall apart and off of the battery, and of course the 2004 Liberty has a non-generic terminal connection to the wire. If I cut the current terminal, which has an extra 2-3 inch copper plate feed, there is not enough wire to connect a generic terminal and still reach the battery post. So, I'm looking for a 'How to' to prepare myself for any unforeseen problems and/or advice on anything tricky that I need to watch out for when removing the base of the battery cable from the starter and attaching the new cable and terminal (1 piece). Thanks in advance to anyone that can help.
Davey
chuckthetekkie
Replace 2006 Front Driver Side Door Lock Actuator
I need to know not only how to replace the front driver side door lock actuator but where to get the part as every place I've checked only carry the right side but I need the left side.
TorrentIV
A Leaf on the Wind
Central Texas
Anyone have a how to or PDF of the JBA ylink extension? Seems easy but I want to be accurate on the install.
