Hey guys - Just a little background.
2002 Jeep Liberty limited CDA build.
I had to let my 03 liberty limited go because Canada would not let me import it at the time. So that went to family in the states, then we purchased a 2002 liberty.
Issue or one of "them" has been an intermittent airbag light, which eventually became an always on issue.
I recently replaced the rad, condenser, heater core, dryer and both l.p lines.
At this time I was able to have a good look at the front impact sensors and discovered both were cracked on the back where the epoxy meets the edge.
Both were replaced with e-bay sensors that appear to be in good shape, however the air bag light remains.
I have checked the seat belt pre-tensioner and after having various ohm results, I removed the shorting clip and now have a 2.4 ohm reading. I think this is a working circuit from what I have read.
Next I removed both air bags driver and passenger to check the ohms on them. Both read 2.4 ohms. It seems like 2.4 ohms is the target for the system.
I then removed the center console to get partial access to the O.R.M. Here is where some concern comes in. There is a harness adapter about 10 "in long with a a female plug on one side and a short pigtail on the other. The pig tail plugs in to the O.R.M and the female connector plugs into the jeep air bag harness.
When I trace the wires from the seat belt pre-tentioner and both air bags I get around 2.6 ohm with exception of one of the air bag plugs on the driver side (not sure if it the low or high speed) side but it shows up with over 3 ohms. I suspect this to be a clock spring issue and have probed the clock sp. What I found is if I put a little pig tail in one side of a jumper and check the female air bag plug facing the dash it will read on three of the four pins. This behavior shows up on both the low / high side pins.
I would expect each pin on the air bag connectors to be isolated through the clock spring and out to the harness. I am about to disassemble the clock spring and see what can be done if anything.
Back to the O.R.M adapter. I do not know if this is some sort of converter, crossover or if it is a straight through adapter to give the mechanic access, but when I check the ohms on the back side of the pig tail they are really high.
Wondering if some one can confirm what this little adapter is doing or suppose to do. Also wondering if I can plug the wiring harness right in to the O.R.M and by pass the adapter.Looks like same plug and long enough to do so.
I would be grateful for some insight.
thank tom
thank tom
