Intermittent engine cutoff at 2500 rpm
Corytrade
Northern California
Hey guys. I posted this on a different jeep forum, but haven't gotten much help yet. Maybe I just went to the wrong set of experts ;)
I have been having an on and off issue with my 2005 Liberty (V6, automatic). It is actually a combination issue. About 1 in every 10 starts, it will take about 3 seconds of engine cranking for the car to start up. When this long engine start happens, the car will drive fine if I keep it below 2500 rpm. However, if I really give it some gas, right at about 2500 rpm, the engine will start what I can only describe as an intermittent cutoff. It will drop power for a fraction of a second, then resume, then drop power again and resume again. It makes this surging/jerking feeling, probably similar to if you were running out of gas (though I have never ran out of gas, so I don't truly know what that feels like). If I turn the car off, and turn it back on again, usually everything is fine. I can drive with no reservations. As I said, it will start fine a few times, then randomly go through this issue again.
When this happens, obviously the check engine light comes on. I had a buddy code read it for me, and it comes up with #4 misfire and cam sensor issue. I took the vehicle to the Jeep dealer, but I really don't trust them. They did a pressure test on the cylinders and #4 is pushing 90 psi, compared to the 150 psi (i think that was the number) of the other cylinders. They said I had a bad valve, and I need to re-machine the heads (only $2000!). I do not doubt that I have a low pressure cylinder. However, I do no think that bad valve is causing the problems I am having, and re-machining the heads wouldn't fix this issue. Since my problem is intermittent, I think it is more of an electronic issue, and not a mechanical one. Usually, by the 3rd or 4th clean start in a row, the check engine light goes off. This makes me believe even further it is an electrical issue, and that everything is operating well in between the bad starts/engine surging.
I recently realized this happened right after I changed the spark plugs from copper cores to bosch platinum +4's. After reading how the Liberty does not perform well with platinum plugs, I just switched back to copper cores last night. I doubt this was the issue the root of the issue, but I figured I might as well get back to OEM parts.
Thank you very much for any possible insight.
dude1116
Pompton Plains, NJ
Well the entire time I read your post I was thinking plugs. Then you said it yourself. See how it runs with the coppers. Although not sure that would drop compression. Someone more knowledgeable will chime in.
Corytrade
Northern California
I did a compression check last night when changing the plugs, and sure enough there was low compression. Maybe the tester isn't that great, but cylinders 2, 3, and 4 were at 90 psi, and 1, 5, and 6 were at 120 psi. The manual said as long as they are within 25% of each other it is okay. So they are all low, but within 25% of each other :Big Laugh:
Rapidrandy
Rossville, GA
I had the same issue with my 2005 Liberty, bucking like a bronco under acceleratrion. The check engine light came on 2-3 times, with a code for the camshaft & crankshaft positioning sensors. I replaced both of them (very inexpensive) and problem solved...
Corytrade
Northern California
Sounds like you had the exact same problem as me. I will be changing the sensors ASAP. Thanks.
