It's here. 2008 Jeep Liberty "KK" - Pics and Specs
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
\:D/ \:D/ \:D/ \:D/ \:D/
Dimensions are in inches (millimeters) at curb weight with standard wheels and tires unless otherwise noted.
Body Style.................................................................................................................. Four-door sport-utility
Assembly Plant............................................................................ Toledo North Assembly Plant; Toledo, Ohio
EPA Vehicle Class...................................................................................................... Multi-purpose Vehicle
Engine: 3.7-Liter, SOHC, V- 6
Availability..................................................................................................................................... Standard
Type and Description............................................................................ 90º V-6, liquid cooled w/balance shaft
Displacement................................................................................................................. 225.8 in3 (3700cm3)
Bore x Stroke.......................................................................................................... 3.66 x 3.57 (93.0 x 90.8)
Valve System............................................ Chain-driven SOHC, 12 valves, and hydraulic end-pivot roller rockers
Fuel Injection............................................................................... Sequential, multi-port, electronic, returnless
Construction............................................... Cast iron block and bedplate, aluminum alloy heads, balance shaft
Compression Ratio.............................................................................................................................. 9.7:1
Power (SAE net, estimated).............................................................. 210 bhp (157kW) @ 5200 rpm (56.8hp/L)
Torque (SAE net, estimated)......................................................................... 235 lb.-ft. (319N•m) @ 4000 rpm
Max. Engine Speed....................................................................................... 6000 rpm (electronically limited)
Fuel Requirement................................................................................ Unleaded regular, 87 octane (R + M)/2
Oil Capacity........................................................................................................... 5.0 qt. (3.7L) SAE 5W-20
Coolant Capacity................................................................................................................. 14.0 qt. (13.25L)
Emission Controls............................................................. 2, mini-oxidation and 1, 3-way catalytic converters;
4 heated oxygen sensors, EGR and internal engine features
Alternator........................................................................................................................................... 160 A
Battery............................................................................................................... 600 CCA, maintenance free
Transmission: NSG 370 Manual Six-Speed Overdrive
Availability...................................................................................................................................... 3.7L V-6
Description............................................................................ Synchronized in all forward gears and Reverse,
multi-rail shift system with top-mounted shift lever
Clutch................................................................................... Hydraulic actuation, dual-mass flywheel system
Gear Ratios
1st.................................................................................................................................................. 4.46
2nd................................................................................................................................................. 2.61
3rd................................................................................................................................................. 1.72
4th.................................................................................................................................................. 1.25
5th................................................................................................................................................... 1.0
6th.................................................................................................................................................. 0.84
Reverse......................................................................................................................................... 4.06
Axle............................................................................................................................................. 3.21
Overall Top Gear............................................................................................................................ 2.69
Transmission: 42RLE Automatic Four-Speed Overdrive
Availability................................................................................................................. Optional with 3.7L V- 6
Description........................................................................................................... Adaptive electronic control
and electronically modulated torque converter clutch
Gear Ratios
1st.................................................................................................................................................. 2.84
2nd................................................................................................................................................. 1.57
3rd................................................................................................................................................... 1.0
4th.................................................................................................................................................. 0.69
Reverse......................................................................................................................................... 2.21
Axle.............................................................................................................................................. 3.73
Overall Top Gear............................................................................................................................. 2.57
Transfer Case: MP 1522 Command-Trac®
Availability............................................................................................................. Standard on 4WD models
Type...................................................................................................................... Part-time, electronic shift
Operating Ranges.................................................................................. 2WD, 4WD Lock, 4WD Low, Neutral
Low Range Ratio................................................................................................................................ 2.72:1
Center Differential Type........................................................................................................................ None
Transfer Case: MP 3022 SELEC-Trac II®
Availability.............................................................................................................. Optional all 4WD models
Type............................................................................................................. Full-time active, electronic shift
Operating Ranges................................................................................... 2WD, 4WD Auto, 4WD Low, Neutral
Torque Split, F/R................................................................................................................................. 42/58
Dimensions and Capacities
General
Wheelbase...................................................................................................................... 106.1 (2694.4)
Track, Front....................................................................................................................... 61.0 (1549.4)
Track, Rear....................................................................................................................... 61.0 (1549.4)
Overall Length, NAFTA Vehicles........................................................................................ 176.9 (4492.9)
Overall Width..................................................................................................................... 72.4 (1838.0)
Overall Height................................................................................................................... 70.1 (1808.3)
Aero
CdA............................................................................................................................................. 12.21
Cd............................................................................................................................................... 0.403
Estimated Fuel Economy, (mpg city/highway)
Reflects EPA methods for 2007 and prior model years
3.7L Gasoline Engine, Manual Transmission, 2WD.......................................................................... 18/23
3.7L Gasoline Engine, Automatic Transmission, 2WD...................................................................... 18/23
3.7L Gasoline Engine, Manual Transmission, 4WD.......................................................................... 18/23
3.7L Gasoline Engine, Automatic Transmission, 4WD...................................................................... 18/23
Reflects new EPA methods for 2008 model years and beyond
3.7L Gasoline Engine, Manual Transmission, 2WD.......................................................................... 16/22
3.7L Gasoline Engine, Automatic Transmission, 2WD...................................................................... 16/22
3.7L Gasoline Engine, Manual Transmission, 4WD.......................................................................... 16/22
3.7L Gasoline Engine, Automatic Transmission, 4WD...................................................................... 15/21
Fuel Tank Capacity, gal. (L)
3.7L Gasoline Engine............................................................................................................. 19.5 (73.8)
Maximum Payload, lbs. (kg), Includes Occupants and Cargo......................................... 1150 lbs. (590 kg)
Towing Capacities, lbs. (kg)
U.S. and export markets other than Europe
All Models Equipped With a Class II Trailer Hitch...................................................................... 2000 (907)
3.7L Engine, Manual Transmission w/Trailer Tow Pkg (Class III)............................................... 3500 (1588)
3.7L Engine, Automatic Transmission w/Trailer Tow Pkg (Class III)........................................... 5000 (2268)
Clearances with 235/65R17 Tires (Domestic 4x4)
Approach Angle, degrees (without/with air dam)......................................................................... 39.1/29.0
Breakover Angle, degrees (with skid plate)........................................................................................ 20.4
Departure Angle, degrees................................................................................................................ 32.1
Weights
3.7L Gasoline Engine, 2WD.................................................................................................. 4030 (1827)
3.7L Gasoline Engine, 4WD.................................................................................................. 4222 (1915)
Accommodations
Seating Capacity - F/R............................................................................................................................ 2/3
Front
Head Room w/o Sun Roof................................................................................................... 40.4 (1025.1)
Head Room w/Sun Roof....................................................................................................... 38.5 (976.8)
Leg Room......................................................................................................................... 40.8 (1036.4)
Shoulder Room.................................................................................................................. 56.8 (1443.0)
Hip Room.......................................................................................................................... 52.7 (1338.1)
Seat Travel............................................................................................................................ 9.0 (229.1)
Recliner Range................................................................................................................... 6.6° to 51.6°
Rear
Head Room....................................................................................................................... 40.3 (1023.0)
Leg Room........................................................................................................................... 38.8 (984.5)
Knee Clearance...................................................................................................................... 1.3 (34.1)
Shoulder Room.................................................................................................................. 56.6 (1436.4)
Hip Room.......................................................................................................................... 48.4 (1229.0)
Recliner Range................................................................................................................. 21.5° to 33.5°
Cargo
Liftover Height...................................................................................................................... 33.3 (844.8)
Minimum Cargo Width Liftgate Opening............................................................................... 47.0 (1194.2)
Minimum Cargo Height At Liftgate Opening............................................................................ 34.4 (873.5)
Maximum Cargo Height Liftgate Opening............................................................................... 35.3 (895.7)
Maximum Cargo Width At Liftgate Opening.......................................................................... 44.2 (1122.9)
Distance Between Wheelhouse Interior Trim ........................................................................ 41.7 (1059.1)
Cargo Volume, cu. ft. (cu. M)
Behind Rear Seat.................................................................................................................... 31.5 (0.9)
With Rear Seat Folded............................................................................................................ 64.2 (1.8)
Body/Chassis
Layout................................................................. Longitudinal front engine, rear-wheel drive or four-wheel drive
Construction.......................................................................................................................... Steel Uniframe
Suspension
Front................................................................................................. Upper and lower “A” arms, coil springs,
low-pressure gas-charged shock absorbers, stabilizer bar
Rear Live axle, upper and lower trailing arms, track bar,
coil springs, stabilizer bar, low-pressure gas-charged shock absorbers
Steering
Type.......................................................................................................................... Power rack and pinion
Overall Ratio.................................................................................................................................... 17.36:1
Turning Diameter (curb-to-curb)............................................................................................ 35.5 ft. (10.83 m)
Steering Turns (lock-to-lock).................................................................................................................. 3.42
Brakes
Availability.............................................................................................................................. Standard - All
Front
Size and Type....................................................................................... 11.9 x 1.1 (302 x 28) vented rotor
with 2.6 (66) single-piston floating caliper
Swept Area (total front)................................................................................ 190.8 sq. in. (1231.0 sq. cm)
Rear
Size and Type...................................................................................... 12.44 x 0.47 (316 x 12) solid rotor
With 1.9 (48) single-piston floating caliper
Swept Area (total rear).................................................................................... 55.4 sq. in. (357.6 sq. cm)
Power Assist Type .................................................................... 8 x 9 (204 x 230) Tandem-diaphragm vacuum
Four-wheel Anti-lock (ABS)...................................................................................................... Standard - All
Electronic Stability Program (ESP)........................................................................................... Standard - All
Parking Brake Type.................................................................................................... Rear brake drum-in-hat
Wheels
Availability............................................................................................................................ Standard Sport
Type and Material................................................................................. Machined and painted cast aluminum
Size.................................................................................................................................................. 16 x 7
Availability......................................................................................................................... Standard Limited
Size.................................................................................................................................................. 17 x 7
Availability.......................................................................................................................... Available Limited
Type and Material............................................................................................... Chrome-clad cast aluminum
Size.................................................................................................................................................. 18 x 7
Tires
Size and Type................................................................................... P225/75R16, all-season, black side wall
Model....................................................................................................................... Goodyear Wrangler ST
Revs/Mile (km)............................................................................................................................ 712 (1146)
Availability.................................................................................................... Standard Limited
Size and Type................................................................................... P235/65R17, all-season, black side wall
Model....................................................................................................................... Goodyear Wrangler HP
Revs/Mile (km)............................................................................................................................ 721 (1160)
Size and Type................................................................................... P235/60R18, all season, black side wall
Model.......................................................................................................................... Goodyear Fortera HL
Revs/Mile (km)............................................................................................................................ 722 (1162)
Availability............................................................................................................................ Available Sport
Size and Type............................................................... P235/70R16, all-season, all-terrain outline white letter
Model..................................................................................................................... Goodyear Wrangler SRA
Compact Spare Tire............................................................................................................... Standard Sport
Full-size Spare Tire w/ Matching Wheel........................................................ Standard Limited; Available Sport
What's April 4th???? Your B-Day or something????
zeke1312
Wait a minute, Marlon went from being sleepy to now he is sleeping.
ryanmcv
Lemont, IL
He's probably talking about the announcement of the 2008 Jeep Liberty.
Trodo
Orange County, CA
Announcement and showing for the 08 Liberty is to take place at the New York Auto Show, which starts on April 6th. So most likely the 4th is press day. If that's what Marlon is talking about.
If not, maybe that's the day he's going to get some wicked good grub.
thecause17
North Huntingdon, PA
jeepjeepster said:
Sooo.. Whats the big deal? The kj looks better anyway. (whistle)
Agreed. \:D/ I really don't care for them, but I'm like that with a lot of new cars, and eventually, a lot of them grow on me.
hyde
I just checked resale value of my KJ, private sale value is 15k \:D/ \:D/
oh oh ...........
hyde
But still, today I drove ML350 for a while and at the end of the day I sat in my jeep, it was like AAHHHHHH. It is like Venus and Mars.. two different planets, and I think nobody could make comparison between them.
An ML350........if that's the one i'm thinking of, you could buy 4 KJ's for the price of it, so it should be 4 times better.
hyde
No believe me, it's got it's pluses, and a lot of them, especially comfort, but as soon as my ass found its place on my kj's driver seat, I felt home. It feels like I am together with the KJ, I am driving it. ML feels like it drives you..
desertkj
Arizona
hyedipin said:
No believe me, it's got it's pluses, and a lot of them, especially comfort, but as soon as my big o'le butt found its place on my kj's driver seat, I felt home. It feels like I am together with the KJ, I am driving it. ML feels like it drives you..
I can agree with that. It sounds weird, but I sometimes have a hard time getting comfortable in luxury car interiors. It just feels too uptight and I guess professional to me. Oh, and I love not having climate control.
