Luke
Interloper
lol .. well whatever music it was ... you've violated somebody's copyright :happy175:
The music ****'s took it down!
Video and sound still works on my end. Did you cut the motor mount frame horns to where the bolt holes are now slotted and open on the top? Either that's an optical illusion, or your engine is going to jump out of it's seat when you romp on it. Be sure to keep the hood well latched to keep the engine from flying out of the bay!
I might be in the minority here but I would have cleaned up the engine bay a bit with everything out. I'd be hurting so bad waiting to drive it for the first time.
Since you've been in there enough, you should know how hefty the stock frame mounts are. And for what it's worth, as far as lifting force goes, only the drivers side of the engine is the one that wants to lift up under torque. You may be perfectly fine leaving the passenger side alone.
Find a older S10 with a 4.3,good chance that it will have broken motor mounts and power brake it in reverse then in drive.The engine will "lift" one way in reverse and "lift" the other way in drive.Nope. The drivers side lifts due to the rotational torque of the engine. Has nothing to do with the drivetrain or which direction you're going. When going backwards, torque is reversed at the trans, but the engine is still rotating in the same direction as before. The drivers side of the engine will lift when in neutral as well.
Are you going to wrap them for heat or don't you think it's needed mighty tight in there.
I'm not sure how I am going to approach the issue of heat dissipation. It may not even be necessary if the tubing is routed correctly. The only area of concern is that the one of the tubes on the drivers side is about 1" from the steering column and I've already decided to reroute it further underneath.
I've read both good and bad things about header wraps and I'd like to read the opinions of the more experienced folks here before I consider them as an option. Sure they help to dissipate heat, but they also, from what I've read, tend to shorten the life of the header.
