Liberty lift confusion!
judderman
Even better the front sway bar bolts are seized
I’ve burnt my impact wrench battery three times, bent a breaker bar and almost yanked the Jeep off the axle stands and it won’t move a bit just spins in place
Not my day
kejobe
NE Ohio
Got a torch? Then get new end links, if that's what your referring to.
It’s not going well...
Any idea how to get the bushing out of the top of the Bilstein to get the new adapter in? I’ve tried a C clamp
You're trying to do what ??
the new " Bushing" just slides right into stock bushing
judderman
Unfortunately it really doesn’t, maybe I’ve been unlucky but the metal sleeve in the bushing on these Bilsteins is stuck like the rubber was molded onto it, won’t budge at all.
You do not remove the metal sleeve, you are doing the wrong end I'd say. One end with the metal sleeve stays, other end always gets the bushing
judderman
Both ends have metal sleeves already, the Bilstein adapter kit from JBA just looks to have a longer metal sleeve... maybe I can just throw washers on the outside of the sleeve like it says to do for the bottom?
Weird, I ordered the 03 Dakota Club Cab shocks but seem to have a different set up than most...
judderman
Spent a full day trying to get the coils onto the Bilstein shock absorbers I’ve bought two sets of spring compressors and both are too big to come out of the coils when the top nut, washer and plate are on...
Am I going crazy? Two days for what should be a simple(ish) task... is this normal?
Done close to 60 KJ lifts, my head is not worth using those junk a** compressors.
Take them to a good shop and let them do it
and 99004 Dakota 4X$ club cab rear shocks ?
What series Bisteins, have installed a ton of them and never seen sleeves in both ends
judderman
Front:
Heading to a shop tomorrow to get them installed, hopefully once the coil over is sorted I can muscle them in fairly quickly.
Glad I got the terraflex bump stops, the stock ones were seriously torn up, almost a triangle they’ve taken some beating. Stock suspension on this I think must have been completely shot.
Rear:
Bilstein 4600
24-185240
2003 Dodge Dakota Club Cab 4x4 - or at least these are the ones that come up...
Length looks similar to the stock and holes are right size for the bolts I think I’m just going to stick washers either side so they don’t clunk around.
judderman
I run the 5100 series on rear of my 03 now 24-185660 with 2.5 inches of lift
This one says compatible with a YJ, does that sound right? I’ll get them ordered now and return the others if it is.
Thanks by the way!
blemoine
2948 are the exact same thing, just means two in a box is all
Stay away, totally away from Rocky Road
clevis lift stay at 3/8 inch, nothing needed just measure and tighten to required specs, or use 3 , 2 inch conduit nuts for measuring purposes
front bumpstops use Teraflex ones made for the KJ
rear use two hockey pucks per side bolted down to the lower spring perch
Frankenlift will give you waty over 3 inches and requires the jeepinbyal upper control arms as well
Not hard to figure out, all has been mentioned 1000s of times here and on LOSTJEEPs over the years
Why 3 inch ?? Just curious is all 927/948 combo gives you 2.5 inches of lift what is so special about 3 ??
and this comes from the guy who ran 4.5 inches for years on a daily driver LOL
front shocks the same as stock, bilsteins are good shocks
rear are Dodge Dakota CLUBCAB 4x4, has to be for a club cab 99-04
I've installed a ton of bilsteins over the years on KJs ride and handling are good
Hey Tom, I'm new here so forgive me for the "noob" question...
You said:
"front shocks the same as stock"
Looking through the threads here, all of the front strut (shocks) seem the same size, even if you go to the OME / Bilstein setup. If that's true (and please correct me if I'm wrong), what exactly gives any lift to the front of the jeep? I understand that putting longer shocks and springs in the rear does that, but it looks like the recommended front setup is exactly the same dimensions as stock? What makes it sit higher?
judderman
Looks to me like a higher spring rating is probably the reason why it’s lifting it, springs are much stronger.
I can vouch for this method having finished it Saturday. The Jeep looks great and I’ve got easily 3” over the worn out wobbly stock suspension.
blemoine
Thanks man! Would you mind posting what your final parts list was?
Springs give lift not shocks, plus how the front IFS is, longer shocks are not needed , just longer for the rear
parts list has been posted many times
the OME 927/948 provides 2.5 inches and from the above comment that is more than likely what he got, plus he was sagged a 1/2 inch or more
You can go higher, doesn't take much to go 3 inches of lift over NEW STOCK height
blemoine
Thank you Tom.
judderman
I’m happy to do a parts list in the morning when I’m at my PC also I will I share lessons learned which are rookie mistakes I made but maybe help someone. I got all my parts and info off this site though like Tom says
blemoine
Thank you judderman!
I know Tom's right - it's all here. However for a newcomer it is SO much easier to see it all in one place rather than crawling through over a decade of scattered information :) I appreciate the followup.
Decade of info, LOL
Its been posted just recently
BUT here you go
OME springs 927 front, 948 rear
teraflex front bump stops
rear 99-02 Dakota CLUBCAB 4x4 shocks
use Bilstein shocks ( www.shockwarehouse )
stocks are stock bilstein
also 2 hockey pucks per side bolted down to the lower spring perch, 3/8 inch bolt, 2.25 inches long with lock washer and nut of course to hold them in
