Jim McClain
So, no clevis spacers and no conduit nuts? I have edited my parts list in my first post to remove the extraneous parts and to add the u-joints. The rear driveline has 3 u-joints, from what I gather, so I should get all 3 and the straps too? I chose Spicer over Moog u-joints because there were too many disappointing reviews on the Moogs. The Spicers are more expensive, but they have great reviews.Jim here is my 2 cents worth
I would get the shocks and springs you have listed
then in the front just do the top plate for 3 inches of lift
Rear do one extra upper iso per side ( so 2 on top , with new one on the bottom
You are right if you are doing it right just replace them
But everything else looks fine on the list
3 inches of lift will not cause a lot of headaches down the road.
Another thing to add may be the rear u-joints. Depending on when they were changed ( or if they ever have ) when going to a different angle sometimes they will give you vibes.
The new list is copied below.
My Parts List
- JBA Upper Control Arms (in)
- Y-Link Extension (in)
- Front Coilover Assembly
- OME 2927 front Coil Springs (in)
- OME 90009 struts (in)
- Moog K3189 & K3190 Front Strut Mounts
- Moog K3186 Coil Spring Insulators (isolators)
- JBA Strut Spacer Plate Set
- Moog K80767 Ball Joints
- OME 2948 Coil Springs (in)
- 1903200 TeraFlex Bump Stops (ordered)
- Rear Bump Stops [hockey pucks] (in)
- OME N132L Shocks (ordered)
- Rear lower coil spring isolator (2)
- Rear upper coil spring isolator (4)
- JBA SS Brake Hose kit for 2½" lift
- Spicer 5-153X U-Joint Kit (3?)
- GMB 260-0443 Auto U-Joint Straps (3?)
