Mark_Annap_MD
- Joined
- Apr 8, 2024
- Messages
- 3
- Reaction score
- 5
Looking for some help figuring out how to trace down wiring diagram for 2003 Jeep Liberty Sport 3.7L. Mice chewed through the wiring harness right beside the master cylinder (see pic). There are 4 black wires that are cut and large chunks missing so it isn't obvious which ones connect. Two wires have blue stripe and two have white stripe. Tested continuity and no continuity between the black and white wires regardless of the combination. Then there is continuity between the black/blue wires again regardless of the combination. I have the Haynes manual but without knowing which systems that harness services I am not sure how to sort out what to look for.
Couple more bits for context, I am the original owner and there hasn't been any previous electrical issues with the Liberty. It doesn't get driven every day but I usually drive it once a week to make sure everything keeps moving and hopefully discourage things like this. It was driven the day before this happened so at least the final blow occurred overnight. Currently it won't run at all, cranks but won't fire. When I plug the ODB reader in it won't even turn on, I know the reader works because I used it on another car on Saturday.
Any insight would be welcomed.
Thanks,
Mark
Thanks,
Mark
