'06 Liberty 3,7. Misfire on cyl 4. Scoped for secondary waveform on its COP and got no signal (tested adjacent COPs and got a good pattern). Swapped #4 COP with one of those that tested good and, again, no secondary waveform. I then disconnected COP primary plug (which is 2 pin) and probed the red wire and got momentary battery voltage with key-on and constant battery voltage with engine running. Just for laughs, I plugged COP #4 power plug into cyl #2 COP next to it and tested for secondary again. Still nothing. Did not test injector on 4.
Is it safe to assume I have a problem on #4's signal wire, Either an open or a problem with driver inside PCM? I don't know if the PCM could have possibly detected a problem with COP 4 and disabled the trigger.
