I have a 2005 Jeep Liberty That I installed a Mopar Remote Start module / installation kit into.
I followed all the instructions. I'm at the point in the programming process where you insert your key, take it out, insert 2nd key, take it out, press program button, then press the remote start button. Jeep basically honks back at me twice which according to the manual, indicates a safety feature issue (brake switch or hood switch) and does not turn over.
I assume the brake switch wiring is working ok because the programming portion which required a brake pedal press/release went through successfully.
I suspect the hood switch because for starters, the switch I got did not match the image/description that was in the Rev. B installation manual. The manual shows the cylinder portion of the switch mounted such that the wire comes out the 'top' of the switch, with the mounting screw plate on the right side and the 2 mounting screw holes at the bottom. The switch I have, to match the wire coming out of the top directions, my switch is reversed from the photo they show and would not allow proper closure of the hood (the switch would hit the vent area as the hood closes.)
Also, in the image, a ground was clearly defined by a round ring connector wire. My switch only had 2 black wires, neither of which had a ring connector. Being that this is a switch on a DC system, is it safe to assume that it won't matter which wire is the ground?
Can anyone offer an insight as to what their hood switch looks like as compared to the Rev B manual? (found here: http://site.justforjeeps.com/guide/82208998.pdf )
If I disconnect the switch altogether, should the system ignore it and start properly? (as a means of trouble shooting / removing that switch from the equation?)
Thanks for any help from those familiar with this system.
