need help please
Alza
Hi guys
My car (2010 Jeep Liberty) wanted to give me fireworks for the New Year :)
ABS, ESP/BAS, traction and 4WD all turned on simultaneously.. I don't know why.. nothing happened
There's no error code's even in the OBD device??
I've seen a lot of people says that it's the ABS sensor that causes it all together
what do you think ? Has anyone had this problem before?
You won't get codes for the ABS system with a basic code reader, thwy only do engine codes. You need to take it to a garage with a proper diagnostics scanner. It's probably just an ABS sensor, the scanner will tell you which one.
You could check all the wiring and connectors for damage/corrosion.
Alza
Ok .. I’ll take it to nearest one and see
Thank you my friend
kiwi_outdoors
my Bluedriver scanner/app does codes other than engine codes (e.g., passenger load sensors and so forth for the passenger restraint system
Just hangin' out.
Get your battery tested. Libertys hate dirty power and will do crazy stuff like this as a result.
Most any chain parts store will test for free. If you have an Advanced Auto near you they have the best free code reader too.
