kjkotlar
If it ain't broke, take it apart to find out why.
After getting some good advice from the members of this forum on what parts to purchase to lift my 03 KJ I have bought all the bits and started the work. The rear end went very smooth but I'm running into a problem with the front end that I hope someone can help me with. I'm using OME springs and Bilstein struts, got the spring loaded on the strut no problem, but when I go to install them I'm having a tough time getting everything to fit. I've got the strut attached on top, not quite tight but it won't drop down and I've got the fork that goes on the bottom of the strut in place but I'm not able to get the bottom of the fork up high enough to insert the mounting bolt that goes through the fork and the lower control arm. As you can see in the attached picture, the fork is about 2 1/2 inches below the mounting point. I've tried several ways of using leverage to try to lift the strut assembly with no luck. My last attempt was to try lifting the fork with a bottle jack in hopes that it would compress the spring and strut, but that just started to lift the whole car off the jack stand on that side. Do I need to use a spring compressor to be able to compress the strut enough to get the fork in place? I don't have one but can rent one if needed (I used a couple of pipe clamps to load the spring on the strut but there's not enough room to use that method with the strut in place. Any suggestions would be appreciated. Thanks.
