New Keys
Hi All,
[Rant]
My ‘08 KK came with only one key when I became the owner in ‘11. It’s pretty beat up by now (‘20) and the buttons don’t work. Three years ago I got a pair of cheap EBay keys because at the time I couldn’t afford $250 a piece for new Mopar keys. I took them to the dealer to be cut & programmed, which still cost a bunch of money.
I’m here to say, now, that was a bad idea. One of them broke within a month. The other is now broken. Waste of money.
I just got a pair of new Mopar keys, uncut and unprogrammed, from a Jeep dealer on Ebay for about $250 for the both of them. I figured now that I have more than one key (even if they are crappy), I could use the procedure in the owners manual to reprogram the new Mopar keys. I just need them cut first.
Well, I have been around to several places that cut keys today and they refuse to cut them. I don’t know if it has something to do with touching people’s keys (Covid risk?) or maybe some kind of liability in possibly helping thieves steal cars, but nobody I’ve gone to will cut them. I am clear that yes, I know they are transponder keys, and yes, I only need them cut not programmed, but it didn’t make a difference. Very frustrating.
I know I could go to the Jeep dealer again, but it would be an appointment and maybe another $100+ bucks I don’t want to spend. Why won’t hardware stores cut automotive keys anymore? Ideas?
[/Rant]
From the 08 KK Owners Manual:
Customer Key Programming
If you have two valid sentry keys, you can program new sentry keys to the system by performing the following procedure:
1. Cut the additional Sentry Key Transponder blank(s) to match the ignition switch lock cylinder key code.
2. Insert the first valid key into the ignition switch. Turn the ignition switch to the ON position for at least 3 seconds, but no longer than 15-seconds. Then, turn the ignition switch to the LOCK position and remove the first key.
3. Insert the second valid key into the ignition switch. Turn the ignition switch to the ON position within 15 seconds. After ten seconds, a chime will sound. In addition, the Vehicle Security Alarm Indicator Light will begin to flash. Turn the ignition switch to the LOCK position and remove the second key.
4. Insert a blank Sentry Key into the ignition switch. Turn the ignition switch to the ON position within 60 seconds. After 10 seconds, a single chime will sound. In addition, the Vehicle Security Alarm Indicator Light will stop flashing. To indicate that programming is complete, the indicator light will turn on again for 3 seconds and then turn off.
The new Sentry Key is programmed. The Keyless Entry Transmitter will also be programmed during this pro-cedure.
Repeat this procedure to program up to 8 keys. If you do not have a programmed sentry key, contact your dealer for details.
NOTE: If a programmed key is lost, see your dealer to have all remaining keys erased from the systems memory. This will prevent the lost key from starting your vehicle. The remaining keys must then be repro-grammed. All vehicle keys must be taken to the dealer at the time of service to be reprogrammed.
turblediesel
memberable
Alaska
When I first got my Jeep I tried to get a simple key cut to use on the door since I've locked myself out with the keys inside before; they wouldn't do it. The reason given was that a chipless key can be tried in the ignition a certain amount of times before the computer commits hari-kari and can't be started even with the proper chipped key. Companies that cut keys are OK with recutting a key that doesn't work but they don't want the liability of replacing a computer and paying the dealer reprogram fees and tow charges.
I kept trying different places and found one that would make one for me which I've used several times. The CRDs require a 2 minute, or more, turbo spin-down period before shut down so it's nice to leave the thing running and locked for a quick run into the post office to empty the mailbox.
Homeward_Bound
I've bought a set of flip keys off of ebay for $50. Had a hard time getting them cut until I went to a locksmith who would grind the keys, no computer. Reason being that the one computerized cutter I finally a local hardware store to try would not accept the aftermarket key. It needed some sort of extra security code. So I guess hardware stores with the computer cutter don't want to mess with anything but chipless keys. Keep looking for a non chain locksmith.
Big Al
Let's get Cracken
Vancouver,B.C.
I've had good luck with using a few guys off of Craigslist in my area. Programmable Key and programming from him was like $60 and I also gave him a key I bought off of eBay to cut that was not programable.
The "Key" search words .. Auto or Automotive Locksmith.
If you live in a major hub it's a matter of making some phone calls, some are even mobile, and can program them.
I locked myself out once, & that was enough for me. I now carry a flat non programmable in my wallet, & 1 hidden outside on Jeep.
I would also like to mention a great product for Ignition, door locks, hinges, hood latch etc.
Very long lasting protection & completely prevents locks from freezing !!
Yes it's been TC tested snow covered, even dipping down overnight to -30c !:)
Ok i'm glad to know i'm not the only ding **** who's locked his jeep's keys in it a couple of times. I don't know what it is about the jeep, but it's happened a lot more as of late.
Jeremy-WI
Home
I have done that at least once but I have a spare key in the house, one in my locker at work and one hidden inside the Jeep with a key hidden on the outside that can only unlock the door.
I had no issues getting keys cut for it, the local hardware store cut me one without the FOB or chip and cut both of the cheap Ebay replacements with the chip and FOB after telling them they were cheap replacements, not factory
rotary_powered
Texas
I've gotten my local home depot to cut a aftermarket key by convincing the guy working it to follow my instructions, your mileage may vary
Had him select on the automated machine to cut a non transponder plain metal key, but when it asked him to insert the blank I had him put in my aftermarket key. I then went and paid for the uncut blank, and all was good
Thanks for the feedback, all. I found a local independent locksmith who cut the keys for me for $5 a piece. :)
Once home, I followed the process in the second post above (owners manual) to program them. Both of the new keys work perfectly now. They not only run the Jeep but they also have working buttons! What a concept!! :D
And now that the buttons work, I have my remote starter working again just in time for winter. ;)
If anyone is looking for a remote starter that won’t break the bank and that you can install yourself, here is a write up I did 5 years ago on that.
http://www.lostjeeps.com/forum/phpBB3/viewtopic.php?f=104&t=81005
Lostintheforest
Thanks for posting this, it worked great for me!
nbas
Greece
I just bought 4 Mopar keys for my 2004 KJ and cut them.
However, when I tried the procedure in the second post above, it simply does not work.
In step 3
"After ten seconds, a chime will sound. " I hear no chime, and when I finally insert the new key, nothing happens.
I know this post is for the KK model, but I have read the same procedure for the KJ model.
Has anybody with 2002-2004 KJ with 2 original keys, has done a similar procedure to program a third key?
I just checked the Jeep's user's book that came with the car when I bought it, and I saw that there is no "Customer Key Programming" chapter. So I suppose that this has to do with Export Models at least exported in Europe...
That’s a bummer, nbas. Maybe it is an export thing, but there is also a limit to the number of keys that can be programmed using the do-it-yourself procedure. If the previous owners made a lot of keys, that could explain why you are out of luck.
Export models don't have it, I had to get a locksmith clone my original key. The dealer should be able to do it with a DRB111
john e denson
I had to take my key I bought online to a dealership to have it programmed.
nbas
Greece
Thank you all!
There are no previous owners. I have the Jeep since new. I still have the 2 original keys. However, since I take it off-road for trips, I thought why not have a third one just for security...
I talked to an ex-dealer who has the DRBIII, they said they will answer next week since the guy who is aware of the DRBIII is on vacation. Let's see. they want to help as they know me for 20 years. The "new" Dealership said they do not repair old Jeeps... Old cars become more difficult to repair year by year... Less repair parts and less knowledgeable mechanics...
Yeah, it's always a pain with dealers, they just want to sell the new electric junk nobody wants to buy. Round here none of the traders will take an electric as a trade in, they just don't sell.
