New KK Shackle Mounts by ATH
AtTheHelm
California
This is a great solution for those who want simple and strong front recovery points. They are individual shackle tabs (sold as a set) that bolt to the factory tow hook mounting locations and accept a standard 3/4" shackle with a 7/8" pin. The mounts are built from cnc cut and bent 1/4" plate and the shackle tabs are laser cut and media tumbled 3/4" thick stock. They bolt up using included grade 8 bolts and 1/4" thick backing plates that sandwich the unibody.
The problem with the factory tow hooks is they use either a dangerous 'm bolt' which is known to rip out of the unibody or a thin 'stud plate'. The stud plate is actually sold as a separate hardware kit, forcing you to buy both if you want any reliability.
Everything you need for installation is included with these shackle mounts.
They tuck up nice and tight to the plastic bumper so maximum approach angle is maintained. Using shackles offers more versatility and safety over hooks, plus they just look good!
They ship bare steel, ready for the coating if your choice. Shackles are not included.
LOST JEEPS • View topic - At the Helm Shackle Mounts
https://m.facebook.com/story.php?story_fbid=1437718686493977&id=1435959336669912
Sounds like the mounting is sturdy and they look good too.
