Kristopher
I'm looking to replace the spark plugs on my 2002 Liberty Sport and am currently wondering which of the two brands (NGK V-Power & Bosch Platinum+4) offers better performance/durability.
Would the copper core resistor spark plugs by Autolite be a good choice? I'm not sure if the NGK V-Power plugs are made of copper. Here are the links to both plugs for comparison. Thank you very much in advance for your help!I agree with everyone else. Just use the NGK copper core plugs. The KJ was made/set up to run on those. They are easy to change anyway. # 6 is the hardest to get to but even so, not really hard. (I just remove my coolant tank.....2 - 10mm bolts) to get a straight shot at it and hand start all of them to make sure I don't cross-thread the aluminum head.
You want Champion copper plug part # 434,that is the best spark plug for yout engine.Gap to what it say's on the emission sticker on the radiator support.
I'll definitely get that done this Friday. I'm assuming I'm going to need to drain the water from the radiator in order to remove the water reservoir so that I can have access to the plugs on the passenger side? With that in mind, should I replace the drained water with just fresh water or should I pour an additive in there as well?You want Champion copper plug part # 434,that is the best spark plug for yout engine.Gap to what it say's on the emission sticker on the radiator support.
