WesChapman
2005 Renegade 92k miles never used off road. 3.7, auto. Completely OEM right down the the original shocks & springs. (yes, the ride *****)
Around 42k miles I starting hearing a faint howling noise from the rear end @ 60 MPH while under load. The noise goes away when coasting. Changed the diff oil at 60K miles. The wear pattern on the ring gear looked normal and the spiders gears looked OK. There was a small build up of a gray slippery gunk on the bottom of the housing, but it was not magnetic, nor abrasive feeling. Kinda felt like the stuff that comes out of my 3 year son's nose during cold season. Now at 92k miles, the howling is much louder. I changed the u-joints and while that corrected a clunking noise I would hear when the ****** shifted, the howling noise didn't change. I start hearing it about 45 mph; it's loudest at 60 mph and then hardly audible at 75 mph. The noise completely goes away when coasting. About two weeks ago I started noticing a slight vibration in the drive train that goes away after a few miles of driving each morning. Called a rear end shop, described the noise and he thinks the rear end will need a complete re-build to the tune of $800 to $900. He also claims he see's a lot of vehicles between 90k to 150k miles needing rear end work. That claim seemed suspicious to me, but in my 20+ years of driving, I've only kept two vehicles for more than 50k miles, so maybe? One was a 1980 Scout II diesel (141k) and the other has been this Liberty.
Is there anything else I could check on my own, before going to a shop?
