Royy
Last week P0430 popped up (Catalyst System Efficiency Below Threshold Bank 2). Around the same time P2096 (Post Catalyst Fuel Trim System Too Lean Bank 1) occasionally started appearing, but this one would disappear on its own after a couple of miles.
In November of last year I replaced the cats and Y-pipe with a complete assembly from Eastern Catalytic. I have put about 12,000 miles on it since then. O2-sensors were (allegedly) replaced last summer, before I bought the Jeep.
I'm hoping the cats aren't actually bad again, so I've been using the O2-sensor data to try to figure out what's going on... and it's got me at a loss.
I replaced the downstream sensors today, with brand new NTK ones. I wanted to do the upstream ones as well, but I couldn't reach the connector on the driver's side, and the sensor on the passenger side appears to be cross threaded... :favorites68:. I didn't have time to deal with that today, so I'll give that another try later.
These are some screenshots of the O2-sensor readings, taken after replacing the downstream sensors:
Screenshot 1 (75mph on the interstate)
Screenshot 2 (75mph on the interstate)
Screenshot 3 (bank 1 at idle)
Screenshot 4 (bank 2 at idle)
https://imgbb.com/
Screenshot 1 & 2 were both taken on the interstate, going around 75mph with cruise control on.
In screenshot 1 B2S1 looks way off to me, it doesn't seem to be properly switching. The other 3 sensors are fine, as far as I can tell.
In screenshot 2 B2S1 and B2S2 suddenly move around a lot more, even though driving conditions didn't change.
Screenshots 3 & 4 were taken at idle, with the engine at operating temperature. Increasing RPMs did not change the waves.
B1S1 seems to be working perfectly fine, but B1S2 (the brand new NTK sensor) on the other hand... or is this normal at idle?
For bank 2 both sensors seem to give weird readings, which I suppose could point to S2B1 being bad.
After this drive, I also had three pending codes in the system. P0430 was back, but I also got P2098 (Post Catalyst Fuel Trim System Too Lean Bank 2, which wasn't there before I put in the new sensor), and P0138 (O2 Sensor Circuit High Voltage Bank 1 Sensor 2, for the brand new sensor).
I have no visible exhaust or vacuum leaks, no noticeable symptoms of anything being wrong, and all fuel trim levels are perfectly fine (within the +/-4% range).
Besides B2S1 being bad, does anyone have any idea what else might be going on here?
https://imgbb.com/
