OBD scanner
ftaa
canada
Cheapest obd scanner that will read tcm ... do the buetooth ones with the torque app do this? or any other suggestions... i dont want to pay 1500 + for a solaris
ftaa
canada
they are all cheap really for bt.... i know the app apparently supports it but i dont know for sure. i can get an elm 327 for like 17 bucks and from what i have read they do read it but others say no... i just want some sort of confirmation... or a cheap real scanner.
Maybe you can w/ the elm327 but looking through torque app which I use with mine doesn't have any transmission data to display.
Maybe some other app can. IDK.
ftaa
canada
ya see what i mean some say they have it others say no... i just dont wanna spend 2 k on this ... should be an easier way to pull the ****** codes like the key trick
RenKJ
Canada
The CRD and JK forums both have the custom PIDs you need for the transmission but i cant find for the 3.7KJ, theres an initial PID you have to use to wake the transmission sensors and a second PID which pulls the data
nullptr
Port Orange, FL
I've got a PLX Kiwi that I like, but I'm not sure if it reads the TCM. It obviously pulls some data from it, as I can see what gear I'm in, though. I'll see what I can find out after work when I have some time to play with it.
Hedsic
Des Moines, Iowa
I had that same thing well on my Mazda and loved it. It was nice being able to get the data from right on my phone.
ftaa
canada
if you can find out and report back i'd appreciate it
twowings
Tulsa, OK
Several cheap...*ahem*...inexpensive models on Amazon...even when combined with cost of app.....
ftaa
canada
i know i just want to be re-assured whichever one i have does what i want ... and there is conflicting reports of if certain ones work or not...
i'know ima end up buying a used snap on solaris for lie 800 bucks but you know... rather spend 100
nullptr
Port Orange, FL
Hm.
Well, I just tried it with DashCommander. I didn't see anything related to transmission temperature.
I then downloaded Torque and setup the Jeep/Chrysler/Dodge PIDs, which caused Transmission Temp to show up on the list, but it still didn't read it.
After looking into it closer, it looks like Transmission Temperature is not a standard PID and is manufacturer (and possibly even model) specific, so you'd have to find the PID for the transmission data point your looking for.
I don't see why the Kiwi PLX wouldn't read the PID, if you knew it. However, you'd also have to know the math correction value to make the raw input make sense.
Seems like it'd just be easier to add a transmission temperature gauge, sadly. Would have loved to get this working.
ftaa
canada
Hm.
kind of off base from what i want ... but i understand ,..... i just wnt to be able to read the tcm trouble codes.... but i guess if it wont read the temp it wont read the codes either.
nullptr
Port Orange, FL
Oh. Hm. Well, see, that's an unknown. I don't have a transmission code to read! I know it'll read engine codes. :shrug:
From my understanding, though, in order to get the real code from the transmission you'll need a transmission reader that plugs directly into the TCM, not through the OBDII port. The OBDII port is just going to give you the blanket 'Hey, something is wrong with the transmission!' error.
ftaa
canada
but the tcm is in the pcm .. which you talk to via obdII
twowings
Tulsa, OK
Perhaps a friendly Jeep service tech or manager would be willing to provide the procedure/codes ?
ftaa
canada
and also extract 50-199 bucks from my wallet but ya i know.... im on a hump about it
