OK, so let's be serious...4.7l swap.
Status
Not open for further replies.
twack
rochester mn
Man with my jeep knocking im seriously tempted to do this, but i want to see you do it first!
JeepCoMJ
SE WI
well, I will be making two sets of motor mounts. Always easier to do two as two takes 1/4 of the time if you're already set up for it.
I could also have a spare ECM flashed and make a harness for you, but this swap is only going to work on an 02 or 03 with 45RFE and JTEC
twack
rochester mn
keep me posted on that
JeepCoMJ
SE WI
Short update with some teaser pics
engine/trans in, trans mounted. Need to think about motor mounts. But mocking up I can see what will and will not fit.
The intake manifold on this one is not one that I will be using. I have the appropriate jeep one along with computer etc. from an 02 jeep grand cherokee. This motor still needs the tone rings swapped on the crank, and cleaned up, but I want the mounts and exhaust done before I ever get to that point, so that it's purely a mechanical issue and electrical to finish.
pics.
fuzzy, but k-member and suspension back up and in
this will need to come back out to be degreased properly before the jeep is able to go back together for final assembly
Motor in with trans bolted up. pan is on a 2x4 wood block between axle and oil pan to hold it in position without the hoist.
driver side motor mount. I'm thinking that the grand cherokee motor mounts should work out for me.
passenger side motor mount
The heater hoses will need to be stretched, in the middle, so that the reservoir and heater core can be hooked up and look proper.
here is your fan hub clearance. You can NOT use a factory e-fan. I will have to cut the e-fan out of the e-fan only fan shroud, and install one directly on the radiator, with a pusher on the other side. The fan shroud itself will then fit in order to duct air efficiently
Power steering gets a little tight but the hoses will all reach and fit with plenty of flex. There's actually too much hose to the U and the cooler, but no big deal
Here's how it sits with the v8 in it. Obviously it will drop a bit more with full fluids, driveshaft, exhaust, everything else assembled. I'll be wanting diesel springs, but it didn't drop the height by too much
This is where it will sit for a week or so while I finish up the engine replacement on the black 02.
TwoBobsKJ
Northern Ohio
Looks great!
It seemed that the biggest fitment issue would be the motor mounts - wondering where they are located on the 4.7 relative to the 3.7. Looks like you have a solution.
Keep us posted! :waytogo:
04Liberty
MD
Awesome. I was looking at doing this swap (still might), but since down the road I intend to swap a 392 in to my Ram, I started thinking about possibly swapping the stock hemi out of it into the Liberty.
JeepCoMJ
SE WI
this swap will only work with an 02 or with one that came with a 45RFE...and has the same computer system as the 16 tooth 4.7. you're looking for a world of hurt.
also, why on earth are you even going to try to swap a 392 in for a hemi....even if it's new gen, the hemi is gonna be more powerful with less chance of breaking
WarVet
Texas
pics.
Hey Brutha,let me know how this goes, If all goes smooth I'll do the same...are you upgrading the drivetrain to avoid failure?
DJSKJ
California
"OK, so let's be serious...4.7l swap."
I not so smart, but I think that a oxymoron.
JeepCoMJ
SE WI
The drivetrain is exactly what came with the 4.7l wj's. the 45RFE is the same strength as a 545RFE and is internally almost identical...it won't break. 242 won't break, and the 29 spline 8.25 is about as strong as a d44, so it will take it. had a 270hp 4.6 stroker in front of an aw4 and an ax15 with 242 and d44 as well as with an 8.25, never had an issue.
as always, the dana 30 is the weak point. it will be fine as a DD
JeepCoMJ
SE WI
or no, because the solid steel is wasted money, and SFA is worthless wasted money...you then open the door to NEEDING a dana 60 rear because IMHO, there's no point doing axle swaps without going overkill...anything smaller is gonna break.
don't swap a solid dana 30 into anything it didn't come in. it's still going to break.
I would do my SFA swap all over again without thinking twice and for the type of wheeling and area there was just so much you could do with IFS and no I would never own a Wrangler,they ride like a$$.
04Liberty
MD
Ummm....yeah, the 392 IS a hemi, it's the one they put in the new Challengers, Chargers and 300's...:emotions34:
Considering I'd be swapping engine and trans along with computers (providing it would actually fit), it's PCI to PCI. It can be made to work. Only a ****** would try to use the 3.7 PCM to control a 5.7
If your planing on a HEMI swap you will need to do a SFA swap or be forever stuck as a 2wd KJ.No room for the front diff and oil pan,even if using the Grand Cherokee oil pan.
04Liberty
MD
Where'd you get the measurements?
Status
