P0610 code plus ABS and Brake lights on
jwilinski
I’m showing a P0610 code with the ABS and brake light on. I’m also noticing that the gas mileage per gallon is decreasing (was 22 mpg a week ago now 15 according to the panel by the interior lights). Does anyone have any experience or advice with this situation?
klc
“It flies like a truck.”
PNW
That code is an issue with the PCM— The Power Control Module. It’s no longer recognizing something. Decreased fuel mileage can result from this.
jwilinski
Also, My vehicle is a 2005 Liberty CRD with 166,500 miles.
It’s a weird code which apparently means the car may be confused as to whether it has a manual or automatic transmission.
klc
PNW
Sounds like the board has gone off. It’s possible to purchase a replacement PCM, but it needs to be flashed to your VIN and mileage. I’ve seen posts here where people get them off eBay.
Try a reboot, drop the battery leads overnight.
