Parking Brake Replacement
Therian
Missouri
I'm about to replace rotors/brakes on my 2004 Jeep Liberty Sport and I figured for the price I would just replace the parking brake ($30 for a set of two) but I was curious the manual doesn't state but is it just rear or all 4 positions? I just need to know if I need one or two sets of them. Thank you.
Just the rear, both sides! Personally, if your E brake works and the shoes haven't fallen apart, I'd leave it.
Therian
Missouri
Thank you, I'm about to hit 200k on my Liberty and it's still rolling stock so it's time to replace them regardless, plus it's the last thing that could be making that damn 10-15mph ticking. :happy175:
Damotee
Cape York, Australia
I did mine a couple of months ago. Its pretty straight forward but a very tedious job. Took me ages and a lot of swearing to pull those springs back into place. There are videos on Youtube that show you what to do.
OK yeah mine was doing that ticking too!
Adam Roby
Montreal Canada
Swapped out mine recently also (3 weeks or a month ago?). Not hard to do but it was quite time consuming. I have yet to get them adjusted properly. I tightened as much as I could with the wheel through the hub, tried the backing up thing... then engage but can't hold the vehicle when in gear or on a hill of any sort. Can't figure it out... everything is brand new... or cleaned like new.
musky
canada
lucky my 2004 has 4 wheel disks i dont know why they still make drums?
Adam Roby
Montreal Canada
The 2006 is 4 discs as well, but inside the rear discs is where the parking brakes go, which are basically shoes (inside of the disk is a drum). Worse of both worlds I guess...
Wildebeest
Ottawa, Ont.
It's a defective parking brake design and should have been a recall years ago.
kejobe
NE Ohio
My '04 has rear disc also. Same thing here, rear disc hub is the parking drum. Ditto on my '14 Maxima, a friends Rouge, and I believe the wifes '16 Compass.
EDIT: My parking brake don't work for **** though on the Liberty. Froze up or something. I have no need for it so I haven't messed with it.
Therian
Missouri
Yeah, I swapped out all the other things that it could be, not because of the tick but because they needed to be changed. :happy175: Would be nice to get rid of it though.....drives me nuts when my car doesn't run/sound right, it makes me think something is going to break.
The engine on this little guy is great though....I foresee me hitting 350k. Next step is transmission flush and brake fluid flush. I also bought some ujoints a few months back but they don't seem to use the traditional size so my grease gun wont pump into them....need to figure out that issue next.
rjkj2005
US
Best time to rebuild the ebrake is during the rear differential service. It doesn't take long to pull the axles once the cover is off. With the axles out of the way the e-brake is very easy to do. Also it is a good way to clean and inspect the backing plate for rust. And to spray some Rust-Oleum on the backing plate after cleaning. Don't forget to clean and grease the lever mechanism on top.
Drum brake style parking brakes are far superior to the caliper style parking brakes.Having rear drum brakes makes the parking brake even more effective.
Lack of maintenance is the biggest downfall and if you use the parking brake alot the next biggest cause is stretched cables which happens alot more then you think.
Adam Roby
Montreal Canada
I believe mine is either from stretched cables or the arms not tightening the cable. It seems to get stronger, then weaker, then stronger... I can't see the adjustment wheel doing that, must be another component... then again I am only guessing.
