Power Steering Pressure Sensor Leak
CALIKJ
California
hey guys don't know if I'm in the right posts or not . I'm new here. I have a 2002 jeep liberty sport 4x4 3.7 V6 I've had my Power Steering Pressure Sensor replaced twice already by a mechanic and it still leaks. Anyone have a solution or a part number where i can purchase one of great quality. Also is it a messy job to do myself if i change it out??what are the steps i should take if i do it myself? anything helps thanks guys:3681700093_1f8b56e8
try changing out to a mopar o-ring or a nitrile one
P/n 05205254
1. empty out reservoir
2. replace sensor
3. refill reservoir
4. jack front up
5. turn steering wheel from lock to lock
6. refill reservoir as needed
CALIKJ
California
P/n 05205254
2. replace sensor
3. refill reservoir
4. jack front up
ill give this a try tonight after work. I've never taken the O-ring off any idea what size ring i should replace it with?
sorry, i don't know the size.
You could buy the high pressure line from your LAP then measure the o-ring then return it I suppose.
