problem with ******
candyman
us
hi to all of you i am new in the forum, just got a liberty 2002 one month ago and having a lot of problems with the transmission,i did a complete tune up including a change oil in the trnny,work for a few days then starting to slip,and engine light come on i got the codesp0867,p0868,p0876,p0841,p0731,p1790,p0944,then i drop the pan again to check on the filter it was ok, after that it work like nothing happen for another 4 days then back to the same ****** keep sliping, any ideas or i am going to need a new ******?
candyman
us
sorry liberty 2002 limited edition 188k,automatic 3.7 liters and 4x4
Did you use the ATF+4 ****** fluid? Anything else will cause problems.
mmc757
Norwich, CT
What do you mean you "checked" the filter?
It really cant be inspected...If you didnt replace it, then you need to start there.
Also, did you do a dummy check and make sure there is enough oil in it?
