jharrisliberty
I am looking to do a 3.5" lift and I have done a lot of reading and searching to clarify most of the questions that I have. I am going to use OME springs front and rear, 927 on front 948 on rear. I am going to get JBA upper a-arms, 3/8" clevis spacers, OME front struts, Ironman 4" rear shocks, terraflex front bump stops, hockey pucks for the rear, and a Y-link extension. So my first question is, is there anything that I need to add to this list? Second is due to the fact that I have a daystar spacer lift at the moment do I need to buy the oem top plates or can I use the set that came with the daystar kit? Third which isolators do I need to replace due to the fact that the daystar lift deleted the lower spring isolators? Lastly so that this lift is level how many extra spring isolators will I need and which ones will I need?
Thank you for all of the help in advance. I am not going to be doing this for some time but I am looking to make sure that my parts list for the lift is complete. If I can afford some of the parts I might do this lift in stages.
